Question about Electrolux EOB5630 Ultrafan Electric Single Oven
The oven stops working
Recently my oven has started cutting out part way through cooking. After a period of cooling it will work again but when heated back up it usually cuts out again. This problem also effects the grill. Whn it scuts out the oven light also stops working. Any suggestions please
  • Anonymous Apr 16, 2008
    Oven also cuts out after a time cooking. Fan stops lights go out and can only be switched on again after a period of cooling- grill the same- waiting for electrician.
  • Millford Apr 20, 2008
    Power light stays ON, but internal light turns off as does fan. Will not turn back on until left for around 10 to 20 mins
    President:
  • Electrolux Master
  • 2,651 Answers
If your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Posted on Mar 01, 2008
Hi, I have an Electrolux EOU 6330 electric grill/oven. In have only used it twice as i have just moved in to the house and after the second use during the cool down period it started rapidly clicking and...
Try turning the power off to the oven at the meter box and leaving it off for an hour or so. This will allow it to fully reset. When you power up again, reset the clock time and set to manual cooking , hopefully , all will work again.
Jun 27, 2014 | Ovens
Hi, I have a Howdens/Lamona HJA3300 electric oven and there is a "booster/turbo" setting to preheat the oven more quickly which you are then meant to switch back to standard before cooking. The problem is...
Turbo often runs all the elements. I reckon that you have a multifunction switch and the other settings (try base heat _ ) still work.
If so >> check fan element
Oct 17, 2013 | Ovens
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
How long does oven clean lock light stay on after cleaning is completed
Generally, on all self cleaning ovens, they heat the ovens to 500 degrees or better, which basically just "cooks" off any spillage and residue to a powder that can be wiped out after the cycle ends. Due to the extreme heat generated during the cleaining cycle, most will "lock" the door until the thermostat cools to the point that it signals the board to unlock. If yours is a wall oven, it may be well insulated and take a longer time to cool off. If a free standing stove/oven, it also is insulated and has to cool and "sense" by thermostat that it is safe to allow the door to open and operations to begin. This is another "safety override" mandated by the FTC and US Govt. And it's a good one. Otherwise, the exposure to suits by the consumer who did not allow the cooling down period would bankrupt the manufacturers. This is normal, the long cool down period, however if you feel it is taking too long, you could have someone check the location of your thermostat bulb and make sure it is suspended in its mounts clearly, so that it may "sense" the correct tempature. Or you could initate the cleaning cycle at a time when you did not need the oven for a period for cooking chores. I'd say, given the extreme temps used during this process, you should expect at least an hour and a half to over three for the cool down to allow the unlock. Check your owners manual and see if there are instructions there as to the cool down period and the lock. Or google the makers name and model # on the web, and check with their Customer Service or Technical Dept. if you don't have a manual. Hope this helps. Patience is a virtue, it's just hard to keep thinking about draining the swamp when your'e up to your neck in alligators.
Sep 26, 2009 | Whirlpool Ovens
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
524 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
