are you sure its DSN and not a DNS error if the latter Open your Internet Explorer browser. It doesn't matter what page your browser opens to as long as it is open.Click on the Tools option at the top of your Internet Explorer screen. Next, click on Internet Options followed by security Tab In the Security Tab, click on the Custom Level tab located at the bottom of the screen.Check the Medium security level drop down box once on the Custom Level screen. You will also need to browse through the options find the setting Access Data Across Domains and put a check in that box to enable the feature. Finally choose theApply option and the exist the program.You might need to restart your computer for the changes to apply hope this helps
Make sure there is no unwanted software in startup run msconfig and disable all the startup option. And uninstall the software from startup. Hope this helps. Please rate my response. Thanks. Have a good day.
Please check Internet connectivity:-
ask IP Address of your connection and the Internet service provider, in x.x.x.x format
let your IP address is 172.90.56.89 and provider's IP is 172.90.0.1
use following commands on dos prompt
ping 172.90.56.89
if it replies it means your Internet card is working well otherwise reinstall it or get it replaced.
if it replies use following command
ping 172.90.0.1
if it dosent reply, take help of your service provider otherwise enable cookies in Internet explorer.
Hi!
You can check this link, this will give you instructions on how make sure that that the connection is right and how to configure the router for internet connection.
Just reply to this post in case you need more help.
Hi Linda........
1. You can disconnect the Rj45 cable from the PC & connect
it directly to your notebook's Rj45 port. You should have access to the internet if a minute or two.
2. if you want access to both, Pc & notebook you'll need a wireless router. Like the link below. Click it. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
You can find these types of wireless routers at places like Wallmart & Best Buy. They come in even smaller packages.
With the software that is included you'll be connected to the internet in no time. Linksys also provides security so someone near to your home can not tap your internet service & get a free ride. Linksys provides setup assistance from day one.
Hope this helps you Linda!
please vote...
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
If you are connecting to a WiFi Access Point from one laptop, and you know the encryption settings and the SSID (name of the WiFi connection) then you can plug that infomation into your other laptop WiFi connection page and you should be able to connect.
The configuration is very similar to XP.. you just need the information to put in on the Vista..
