Question about Magic Chef MCBR440 Compact Refrigerator
Tried to lower temp...but it raised instead...can't figure it out
I have a compact Magic Chef MCBR440 and the freezer doesn't keep ice cream cold enough to stay solid, nor ice at all.
its controls are simple yet I don't understand them:
there is a dial that goes from OFF, then 1 thru 7...so I assume that when my dial was at about 5.8 and I still wanted it colder, it seemed like a good idea to turn it to 6.5.  Well, there is also a sort of button in the center of the dial.  I pressed it.  It went in and stayed in.  It made me nervous so I pulled it back out and then I though, why not?  And I pressed it back in again.  Well I woke up to water everywhere.  I failed to mention the freezer part could use a good defrosting--but it wasn't that bad.
What is the button for?  And How do I get my refrigerator cold again?  Magic Chef's website doesn't have a manual for this compact. Fridge had been working well...just won't keep ice or ice cream solid oor forzen really...i can't even keep frozen veggies or anything like that because the water in the packages won't stay frozen.
Any help much appreciated.
-Steve
  • 2 more comments
  • Anonymous Mar 12, 2008
    have same problem
  • Tony King May 29, 2008
    I brought two brand new 4.5 Magic Chef refrigerators model MCBR465S on 5/23/08 at home depot fallowed the instruction on the start up and both will not keep drinks cold. They both are at the lowest setting and are above 55 degrees F.
  • Anonymous Sep 08, 2008
    not cold enough
  • johnwithsame Dec 12, 2008
    same problem.
My daughter has an MCBR445w1, probably a similar size dorm refrigerator. It has died. I brought it home tonight to try and get it repaired. The red button in the center of the thermostat dial defrosts the unit. That's why you got the flood. On her unit, 1 is the warmest, 7 is the coldest. I'd turn it to 7 and see what happens. Keep dust off the coils if they are exposed.
I have a feeling these units are just bad refrigerators, but I will try and get hers running. Good luck with yours.
Posted on Mar 03, 2008
Why doesn't it freeze ice
may be a leakage of gas from the compressor
Jun 06, 2012 | Magic Chef MCBR440 Compact Refrigerator
Freezer isn't freezing ice cream what temp should the number be on for freezing ?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Magic Chef MCBR440 Compact Refrigerator
No refrigeration
You punctured the sealed system. Refrigerant has leaked out.
Jul 27, 2010 | Magic Chef MCBR440 Compact Refrigerator
The freezer is cold but the refrig box is not. What can be done
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 07, 2010 | Magic Chef MCBR440 Compact Refrigerator
Freezer ok but bottom refrigerator not getting cold,what should i do,lanlord not helping
Switch off for 12 hours and do a proper defrost. Looks like the evaporator fan motor is jambed due to an ice build up. retry.
Jun 05, 2010 | Magic Chef MCBR440 Compact Refrigerator
Hot motor
Replace the start relay and overload. Sea Breeze
Aug 03, 2009 | Magic Chef MCBR440 Compact Refrigerator
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Hole in freezer
there is a way using a special resin but it is not a reliable repair and you will then need special gear to regas
write it off
Aug 31, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
1,611 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
