Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Convergence problem Hi, My name is Ben Walker. I think I'm having a convergence problem from what I have been reading from other people's issues. The screen looks like a 3D picture. It looks like the red, green, and blue are not aligned. I have tried the auto and manual convergence, with no luck. In the Manual convergence, the red appears to be off on the vertical alignment. The remote doesn't make the adjustment to align those lines. The TV is about 5 years old. I have looked inside, but I'm not sure what to do. I would appreciate any help you can give. You can reach me at bwalker@meti.com. Thanks, Ben
  • 1 more comment
  • atony79 Aug 31, 2008
    I Have the same exact problem!! And dont know if i should fix it my self or not If its an easy thing to do i can. Can some one tell me exact parts that i need to fix.
  • Anonymous Sep 01, 2008
    After having a cable box and internet modem tower put on the jvc tv the picture started having convergence problems than a few days later the picture went completely out. I have been told that the main board is fried and I would need to send away to get part. Is this a simple fix
  • britttribe Nov 09, 2008
    Our TV is also on the "blink" First the green went out of convergence, but we put a piece of paper over the green light and (although it was off color) if seemed to fix the picture. Now the red and blue are out of Convergence. I can not fix any of the colors with the menu screen. I really do not want to pay $400 to have this probelm fixed when I could buy a brand new one for that. What should we do?
Could you tell me were can I get a JVC AV-56WP74 Convergence repair kit
Posted on Aug 31, 2008
  • 2,336 Answers
Hi Mr. Walker,
The convergence failure seems to be very often on these rear projection TVs.
This repair might not be a DIY, but is not difficult but basic soldering skills are helpfull to do it.
Check this link to see the parts that need to be replace, the ICs have STK at the beggining and other numbers after.
http://www.electronic-repair-kits.com/STK392-560.htm
Good Luck.
Posted on Mar 01, 2008
    Scholar:
  • 133 Answers
Sometimes these IC's are mounted on a seperate board. They use STK392-110 IC's . They are mounted on a metal heat sink that are fairly large . Also around them are resistors or fuses that protect them . The resistors tend to look alittle burn't but the fuses must be checked with a meter and are not glass fuses. They also look like resistors but start with a " F " letter . You might look to see if they have loose connections as well , this can also be your problem. Sometimes the IC's are mounted on board below the picture tubes , Thus meaning you'll have to access it thru the front of the tv removing the front speaker grille then removing the they access panel . Good luck
How to change chips rca
I think youre refereing to convergence Issues?? If so your model doesnt have IC chips like most other brands. If your model has a convergence issue its fairy easy to fix. let me know if the issue is convergence or not and I will assist you with the issue.
Oct 24, 2011 | RCA R61WH76 61" HDTV
How do I fix a converence problem?
Hi.
First try using Autofocus. If there is a convergence problem this won't fix the problem.
Try using the convergence alignment procedure from service manual.
Here the procedure that works on most Hitachi rear projection.
Here the grid with convergence problem
If the procedure does not work, then the two STK392-110 on convergence board must be replaced.
Before replacing the ICs you can test the pico fuses located on convergence boards. Simply read ohms to test if they have continuity.
Better also testing components on convergence board like resistors located at the base of STKs.
After removing the old STK, the new ones must be re-soldered using cooling paste.
Price for single IC can is about $8/$20. I think
STK392-110 on this model can be better replaced with STK392-150. I suggest contacting the seller on this.
The service manual is available here.
Jan 12, 2010 | Hitachi 50SBX78B 50" Rear Projection...
I've a mitsubishi ws-65909 and the picture is out of synch. Went to the convergence menu and I'm unable to get the blue in line with red and green and the blue convergence grid can't seem to be realigned....
Hi my name is Roety,
I can help you with your issue ,
If you can solder you can replace the Convergence ICs
A repairman would charge about $400 to do it for you
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 06, 2009 | Mitsubishi WS-65909 65" Rear Projection...
RCA P52960 Problem (bowed picture)
Normally this is either bad connections on the convergence ICs or defective ICs. If you can solder, you should be able to fix this. First locate the convergence ICs: large black ICs attached to a heat sink that shouldbe marked STKxxx. Try resoldering the pins on these ICs first. If that fails, replace the ICs.
Keep me posted.
Dan
Nov 20, 2008 | RCA P52960 52" Rear Projection Television
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
Power up issues
Bad new convergence amp IC's......What part # did you use
and what quality were they ?................read some of my
convergence repair solutions........................T.
Mar 06, 2008 | Philips 50PP9202 50" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Sony HDTV Convergence Issue
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Nov 30, 2007 | Televison & Video
Hitachi Rear Projection
Hi! Guy,
I don't think your problem was caused by lightning. It sound like defective convergence ICs. This must be checked and verified by a qualified service tech.
Toprol
Oct 11, 2007 | Philips 60P8342 60" Rear Projection...
Power supply/convergence issue...
Your Projo is a complicated piece of equipment, involving 3 picture tubes (like 3 tv's), convergence failures are extremely common, I dont think $550 is totally unreasonable, but I dont think it is a power supply issue if it is just effecting 1 color, usually it would cost around $100 parts $300 labor to repair, might be a little high, I suppose they are also charging you for pickup and delivery, I hate taking sets into office as that sometimes jars stuff loose or cracks boards.
Jul 10, 2007 | Panasonic PT-47WX51 47" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
159 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
