Question about RCA TH1101 MP3 Player
Power will not stay on
We have replaced the AAA battery and the power will not stay on. It will light up like it is going to come on but it goes right back off. Please advise
  • byron_89 Mar 02, 2008
    It blinks on and go off. I have replaced the batterys several times.
  • Anonymous Mar 07, 2008
    is the battery the only way this MP3 plays?
    Can I charge it on my computer? or is battery the only way
I am asking if I can charge this MP3 player on my computer or does it just use batteries?
which suck if so
Posted on Mar 07, 2008
You need to get a usb jack. Next you need to plug it into your computer and then plug your mp3 into the other side of the cord. Leave it pluged in for about 2 hours and your mp3 will be charged and ready to go!
Shelby
Posted on Mar 03, 2008
Ford Escape 2003 V6 Limited
replace the battery with a bigger amp rated one
Mar 23, 2017 | 2003 Ford Escape
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
Why does my screen go black?
The two most common problems with Viewsonics are bad capacitors on the power supply board and bad fluorescent lamps. If the background light comes on and then goes off after a second it's probably a fluorescent tube problem and not worth fixing. Capacitors are easy and cheap to replace. Bad ones look like tiny little AAA batteries with the tops rounded from heat and pressure.
Mar 28, 2012 | Computers & Internet
When i power down my computer all lights go off. Then after a few seconds the light 2nd from right shows green and stays on even though the computer is off.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Dell Inspiron 1300 Notebook
AAA said battery was dead and starter was bad, it would only click once until the battery was completly dead. Put a new battery in and had interior lights, etc. Tried to turn it over, and only one click...
iwould check positive and negative power at battery end and at starter and engine block end
also check power at any distribution block (points) for corrosion or partially brocken connection
or loose at mounting points
Apr 06, 2011 | 2000 Honda Accord
Why does my battery keep going dead I have relaced it 3 times a new alternator if the car sits for 2 days or more and is not started and ran the battery is completely dead
BATTERY DRAINS ARE TRICKY. TURN OFF ALL SWITCHES, CLOSE GLOVE BOX. MAKE SURE GLOVE BOX LIGHT IS OUT. OPEN THE HOOD. DISABLE THE UNDER HOOD LIGHT. CLOSE ALL THE DOORS. MAKE SURE ALL COURTESY LIGHTS ARE OUT. DISCONNECT NEG. BATTERY CABLE. USE 12 VOLT TEST LIGHT, CONNECT ONE END TO A METAL PIECE ON THE MOTOR FOR GROUND. FASTEN THE OTHER END TO THE NEGATIVE BATTERY POST. IF THE LIGHT IS ON, THAT MEANS THERE IS A BATTERY DRAIN. LIGHT NOT ON, NO DRAIN. IF THE LIGHT IS ON, FIND THE POWER BOX NEAR THE BATTERY. PULL OUT ONE FUSE, IF THE LIGHT STAYS ON PUT HE FUSE BACK, PULL OUT THE NEXT FUSE. IF THE LIGHT STAYS ON PUT THE FUSE BACK . REPEAT THIS UNTIL THE LIGHT GOES OUT, OR GETS VERY DIM. OUT IS BETTER. WHEN THE LIGHT GOES OUT, THAT IS THE CIRCUIT THAT IS DRAINING THE BATTERY. REFER TO OWNERS MANUAL TO IDENTIFY THE CIRCUIT. IF THE LIGHT NEVER GOES OUT, REMOVE THE WIRES FROM THE ALTERNATOR. IF THE LIGHT GOES OUT, ALTERNATOR NEEDS REPLACING.
Jan 15, 2011 | 2003 Ford Mustang
Occasionally Battery light goes on momentarily
could be a defective alternator, but the mechanic will need to check it while the light is on. I know that sound like BS but if he checks it while the light is off, of course its going to check good.
Sep 21, 2009 | 1992 Honda Accord
Dell Dimension xps R450 won't boot
MAYBE A POWER SUPPLY PROBLEM OR THE CMOS BATTERY IS OUT OF JUICE, YOU DIDNT KNOW THAT YOU HAVE A BATTERY THAT KEEP EVERY THING WORKING RIGHT.
NOT KIDDING
CANDYMANGANDY
Jan 19, 2009 | Dell Computers & Internet
Sennheiser TR136 Wireless Headphones Nothing Happens
Replace the NiMh batteries. They might be bad. Could happen during power surges as you indicated you had. Let them charge up fully 14-18 hours as the book suggests.
Aug 25, 2007 | Sennheiser RS115 Wireless Headphones
RCA TH1101 MP3 Player Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
