Question about Watches
Opening back of watch for battery replacement
I cannot get the back of this watch open - advice is to prise the back of watch where there is an notch, but this is completely smooth all round, and it seems impossible to get a knife or screwdriver into the slit. Advice please.
  • Anonymous May 09, 2008
    There is no area that has a gap
  • 29 Answers
Turn the watch sideways & look around the edges of the back of the watch. You may have to use a magnifier to do this. Look for an area that has a gap. Put the knife there & pry it open. Hope this helps.
Posted on Mar 01, 2008
  • Rahul229
    Rahul229 Aug 31, 2014
    how did you put the lid back?
  • Barbara Phillips Sep 06, 2014
    If the back has a little notch in it line it up with the crown and push it back on. If you cannot get the back on by hand, you might have to put in a press. If you don't have a press you will have to take it to a place that does watch batteries.
Is the back of my generva watch 5573 s a pop off or screw off?
Best to take it to a jeweller as battery replacement if not knowing how can damage the movement. Otherwise a screw back has little notches on the side of the back and a press back is smooth. You will need a back opening knife to open.
Nov 27, 2017 | The Watches
I need to get the back off my new ice watch to replace battery but I can't? Anyone know how please?
Waterproof or water resistant watches usually need a wrench to unscrew the back. I use a pair of 90 degree circlip pliers. A jeweller would remove the strap and fit the watch into a holder before using the wrench.
Few jewellers would guarantee the water resistance of a watch after fitting a new battery. If it is required a watch be returned to its original specification it must be returned to the manufacturer or an agent for battery fitting and pressure testing.
Some watches have a back that is pressed into place. Fairly easy to prise off but very difficult to replace without the tools. This type does not have the grooves a wrench fits into.
Apr 10, 2016 | Ice Watch Watches
W to changebattery #65041g
Changing the battery on most watches is fairly straightforward and needs only the usual tiny screwdriver, insulated tweezers and a large measure of patience and good eyesight.
The main problem is usually opening the case and in the case of a quality watch that is guaranteed waterproof it really should be returned to the manufacturer for battery fitting and pressure testing. If testing isn't carried out after the case has been opened the watch realistically then becomes merely water resistant rather than waterproof.
Usually it is the back of the watch case that must be opened and in the case of ordinary non-waterproof and non-water resistant types it is a simple matter to prise the back off with a thin blade and then refit it with finger pressure.
Water-resistant watch cases that have a priseable back often need the back pressing back on with force supplied either by a purpose-made press or a large bench vice. In both cases adapters are needed to prevent damage to the case and the crystal.
A lot of watches have a back that unscrews and strictly a dedicated key, wrench or spanner is needed for this task. I have managed to overcome this problem a number of times by pressing other tools "that look as if they might do the job" into service. I cannot say what it was I used as I wandered around my workshop just trying things. I think the last time a particular circlip plier did the trick.
Simpler to take the watch and have someone else replace the battery I think.
Feb 20, 2015 | Timberland Watches
Which battery will i need for dkny NY3715
if you use a small instrument, to pop the back of your watch off, look inside, and carefully, make sure you do not touch the small coil, (it looks like a copper colored tube) remove the battery, on the back of the battery, you will see numbers, such as a 370R or 385LRW that is the size of your battery. go to your local jewelry store, or sometimes, a dollar store, and get the same battery, pop it in. when replacing the case back on your watch, be really careful, sometimes there is a VERY small notch, or indent, this indicates where it needs to be positioned. if you see a notch (not every watch has this), you need to line it up with the watch stem. The notch is there to make sure you do not bend, or sometimes break the watch stem. good luck!
Jul 17, 2011 | Watches
I need to know how to replace the battery in my fossil watch. how do i get the back off to check the battery
IF YOU LOOK AT THE BACK THERE SHOULD BE A GROOVE IF YOU GET A PIN IN IT IT SHOULD PRISE OPEN OR A SMALL JEWELLERYS SCREW DRIVER
Jan 28, 2011 | Fossil Blue watch #AM3423 Watch for Men
How do you remove the back to replace the battery. Does the back unscrew or does it snap off.
if its flat with no notches then you can use a pocket knife or small flat blade and look for a notch underneath the case back, there is usually an indentation where the case remover can slip in . Then you have to carefully force the knife inside and wiggle it up and down till it pops off. Be very careful you can cut yourself doing this or even damage the watch by slipping the blade inside and ruining the movement.
If it has a screw back you would see notches on the back of the case going around the diameter usually 6 or so notches. There you would need a special watch opener tool that fits into those holes and would unscrew it.
I would recommend taking it to a fast fix or batteryplus for about 7 dollars you can have them replace it. That way you can prevent yourself from ruining your watch or hurting yourself.
if you do open the watch up be careful not to touch the copper coil if you scratch that you will ruin the movement and need that replaced. if its flat with no notches then you can use a pocket knife or small flat blade and look for a notch underneath the case back, there is usually an indentation where the case remover can slip in . Then you have to carefully force the knife inside and wiggle it up and down till it pops off. Be very careful you can cut yourself doing this or even damage the watch by slipping the blade inside and ruining the movement.
Oct 14, 2010 | Guess 10543L1 10543 Watch for Women
Cannnot find notches in back of watch. I have a
If there are no notches on case back, your 3 point tool has no use. You need watchmakers knife (or pen knife) for opening case back. Use an eyeglass and carefully examine case back all the way around. You will find tiny groove ''lip''. This is exact point where to insert the blade and pry up. Rate me, plz.
Mar 30, 2010 | Watches
Can't get the back off the watch to change the battery. No indentation to suggest where to open. What do I use to open the watch--how do I go about doing it?
Take your watch to a dealer in that brand. I'm guessing that your watch has square notches around the underside. The dealer has a special tool that will fit into these notches and the back will twist off as it is threaded onto the watch, not pressure fitted into it.
Jul 04, 2009 | Timex 27191 Wristwatch
Armitron y121e watch
If your Armitron has a set of 6 inset notches around the back, as does my Y121E 20/1791F Armitron Diamond, that's a screw-back case that does _not_ pop off or pry off. You'll need a case opener tool, which is basically a small tool with adjustable-gap jaws that fit into two notches on opposite sides of the case and let you unscrew it. Wal-Mart sells this tool for about five bucks, and it'll pay for itself soon enough, as many watches have screw backs, and this will fit most anything you find. Head for their jewelry department and you should find the tool hanging up with the replacement watchbands and batteries.
The case is probably screwed down fairly tight against its O-ring seal, so make sure the tool is seated properly in the case notches, and turn it slowly and firmly counterclockwise to work it loose.
If your watch is like mine, it'll take a #377 cell, but wait until you've opened yours up to be sure.
Sep 03, 2008 | JCPenney Armitron Sport Link Bracelet...
To replace battery of pocket watch
My son has a Timex pocket watch-I just got the back off with a very tiny flat-head screwdriver- the niche or indent you're looking for is almost indiscernible; look very closely, the edge of the back barely deviates from where it meets the edge of the front piece. Looks more like a flaw than an intentional point of entry
May 29, 2007 | Fossil VT2654 Pocketwatch
Watches Logo
1,492 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
