Question about Dryers
Samsung DV4006J I HAVE THE BACK OFF IT THE BELT LOOKS LIKE IT CAME OF A PULLEY. IS THERE A CONFIGURATION TO PUT THE BELT BACK ON?? PROBLEM: HEAT WAS WORKING BUT DRUM WAS NOT MOVING ;:
  • 41 Answers
See:
http://www.fixya.com/support/t420249-samsung_dv4006j
Posted on Jul 01, 2009
  • Chris Goulet Jul 01, 2009
    Sorry, I meant see:
    http://www.fixya.com/support/t1210394-sa...
    President:
  • 1,314 Answers
Yes the belt will go on the motor shaft then the idler pulley that keeps the belt tight will go on the outside of the belt after you pull it back to get tension on the spring
Posted on Mar 02, 2008
WE HAVE REPLACED THE IDLER PULLEY AND BELT FOR OUR SAMSUNG DRYER AND NOW IT SPINS WITHOUT ANYTHING IN IT BUT I PUT A LOAD IN AND IT STOPS SPINNING UNLESS IT IS 5 OR 6 ITEMS...WHY IS THIS...
Samsung Dryer Not Spinning Replace Drive Belt 6602 001655
Attached is a you-tube video just in case.
The only reason I can think of is that the belt tension is not enough. check the belt routing over the idler. Does the idler pulley return to the same approximate position as it was before? (or as in the video?) Is the belt too big? I fall that looks good, try cleaning the drum in the area where the belt contacts it.
May 23, 2018 | Samsung Computers & Internet
Need to know the configuration for installing a new belt on a Whirlpool AWA9708 7kg dryer
your model number doesn't show up but all whirlpool belts go on the same way,put the belt under the idler pulley and then onto the motor pulley,you have to push the pulley back towards the motor and then loop the belt onto the motor pulley and you want the ribs to be down touching the drum
http://www.youtube.com/watch?v=CFnXwmUb4f4
hope this helps and next time send the full model number off of the machine,just open the door to the dryer and look around the opening where you put the clothes in you'll see a tag with the full model number
Apr 09, 2013 | Dryers
The belt has come off my dryer and I'm tryint to put it back on, how do I get a digram of what it looks like when the belt correctly back in place?
It is something that you can repair yourself
You probably have a tensioner that has broken.
I am sorry but I do not have the Samsung routing available to me.
Below is a chart of the most common routing of dryer belts.
The part that has failed on your unit is probably the idler pulley/brackett.
You should be able to repair it without having to remove the drum
http://www.applianceaid.com/images/belt-config.JPG
Apr 26, 2011 | Samsung DV218AEW Electric Dryer
Serpentine belt configuration
Accessory Drive
Component Locations 3.0L (2V)
3dde941.jpg Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Water pump pulley
Component Locations 3.0L (4V)
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 19D784 A/C clutch pulley 4 6A312 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
I posted the serp belt configuration for both engines. thanks
Sep 24, 2010 | 2003 Ford Taurus
I have a Murray Ultra lawn tractor model #4681X6B and the blade drive belt is stuck between pulley and some type of guard that looks like a brake pad, and for the life of me I cannot get the belt back onto...
Try taking the belt off of another pulley, put it on the other ones and the tensioner pulley, then start it on the last one and pull the tensioner and get the slack in the belt and roll the pulleys and it will feed the belt on that pulley.
May 10, 2010 | Garden
I need the drive belt configuration for a 1988 Jeep Cherokee.
To replace belt, first loosen the pivot and slide bolt on the steering pump, then use the jack bolt below the pump to move it. Belt goes (ccw) around outside of ps pump, under idler pulley, over a/c compressorover alternator over fan pulley, over crank pulley over water pump and back to the ps pump. best bottom (grooved area) should match with any pulley with grooves, back of belt should contact smooth pulleys. 9example...grooved part contacts ps pulley, smooth back goes under idler pulley) When finished the water pump should spin ccw (I've seen them put on incorrectly so it turns backwards) Tighten jack bolt till the long strech of belt is giving about 1" deflection, then lock pivot and slide bolts down.
Nov 28, 2009 | 1988 Jeep Cherokee
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
How to put the belt on,
there is no way of tensioning the belt so it is a very tight fit
put belt round motor pulley first then start belt on large pulley and turn large pulley by hand and it should go on
Jun 24, 2008 | Washing Machines
Dryers Logo
498 people viewed this question
Top Dryers Experts
Marvin
Marvin
