Question about Minolta CF2001 Copier
Minolta DC 2360
Copies are coming our Black, even when i have it on light
  • Minolta Expert
  • 1,326 Answers
A C2001 is a problem with the primary charge carona ass'y. Check to see that it installed correctly or puched in all the way or it could be that the post corona wire or grid is broken or fell off.This would cause your dark copies.
Posted on Mar 02, 2008
Black marks in copies
Do they move across the page as differtent copies come out?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 13, 2014 | Minolta EP1031/1031F CS/PRO Copier
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Makes only black copies.
Hello sir; when you make a copy open the cover then yo can see does the exposure lamp is on if not replace it.
Aug 23, 2009 | Minolta Office Equipment & Supplies
HALLO. >I HAVE GOT A KONICA MINOLTA C300.THAT IS MAKING LIGHT COPIES EVEN WHEN PRINTING FROM MEMORY A DEMO PAGE. PLS! ASSIST WITH SOLUTION TO THIS PROBLEM?
Have you check, the image units, for is the light copies a b/w issue or a color issue? have you check the consumables does the transfer belt or fuser unit need replacement. are image units OEM or third parties?
Aug 17, 2009 | Konica Minolta Office Equipment & Supplies
The copies are coming out almost all black and the drum is completely black
The exposure unit malfunction.The exposure lamp not lighting or the wastw toner box is full or the OPC drum cleaning blade damaged.
Aug 05, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta dirty copies
remove the filter and housing from the i/u and vac out the spilt developer, do the same on the underside, if background/halo is still there increase the seconary transfer value by 2 for plain paper
Jun 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Why do my copies come out so light?
I found that I had to adjust the settings or my copies were almost illegible. Instead of copying at greyscale or black & white, try setting for color copies (even if using a black & white laser printer) and 600 dpi. It takes a few seconds longer to scan, but you get very clear copies that way.
May 01, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Minolta Copier EP1083, copies are coming out mostly black
What you mostly need to do is to clean the optics under the copyboard glass the mirrors are mostly dusty... I would use a soft dry cloth to wipe the mirrors off. There is a mirror under the "Black Box" I would also, use a lightly damp rag with rubbing alcoh. to wipe OFF the scanning lamp & reflector. Cleaning the optics should get read of the dark back ground, but the drums are only good for 80k... You may need a new OPC drum & blade. Good Luck
Mar 02, 2009 | Minolta EP1083 CS/PRO Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
