Question about Acer Aspire 5100 Notebook
Touchpad issue My touchpad woks fine most of the time - I've set the speed, sensitivity etc just how I want it. However, when I'm doing something involving fast movements, gaming for example, it has a very annoying habit of displaying a double arrow type graphic right next to the pointer which then stops it from moving momentarily. I've been into all the settings for the touchpad and I can't find out either what this arrow graphic is, or how to turn it off!!! Any help would be very gratefully received!
  • Denise_UK Mar 01, 2008
    A mouse isn't an option unfortunately - laptop on knee on sofa!
It is suggested 2 u that u should use your touchpad as less as possible specially not in gaming purposes. Use an USB optical mouse to resolve this problem.
Posted on Mar 01, 2008
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Touchpad too sensitive
In the Windows Control Panel, select 'Mouse'. It allows you to change the speed at which the mouse responds to the touchpad. Lower the setting until the touchpad has the desired sensitivity.
Jan 24, 2013 | Gateway Computers & Internet
Dell xps m1330 vista home curser jumps when typing
Have you loaded your touchpad drivers? The only time I've ever seen than happen is when the touchpad drivers aren't loaded. The touch is extra sensitive if your palm(s) just barely touch the pad.
By loading the touchpad drivers, you should be all set
Oct 27, 2012 | Dell XPS M1330 Notebook
Touchpad not working correctly..
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
hope this helps
Jun 27, 2012 | Samsung Np200a5b-a03us Notebook
Compaq CQ60 Presario - touchpad issue. Touchpad is sometimes slow, sometimes seems to stick or have dead spots where, when I move my finger across, the cursor doesn't move. When I want to click on...
if it has recovery partition go into that and remove and reinstall it if you get stuck turn it off and it will auto reinstall the touchpad to see if you got the recovery go into the start menu and type recovery if it pops up enter go into advanced options and reinstall it ok good luck ooh ps these do wear out but like more than a year or 2 so you just need to reinstall it most likely good luck ok and have a usb mouse on hand just to be sure it goes easier than harder ok
Dec 21, 2010 | Compaq Presario CQ60-212US Notebook
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
How do I manage the mouse pad sensativity on my VIAO notebok computer
You should be able to manage the touchpad (mouse pad) settings by going in to control panel --> Touchpad.(or "Dell Touchpad"). There you would find the touchpad settings where you could adjust the sensitivity for the touchpad.
Please let me know if you face issues finding the settings.
Thanks.
Feb 03, 2010 | Computers & Internet
I have a Sony Vaio Laptop and earlier today my touchpad was working fine now it's not. How do I unlock/fix this? Thanks
Check your mouse settings in the control panel. Go Start - Control Panel - Printers and Other Hardware - Mouse and check your mouse touchpad settings. There might be something unchecked or not working. If you have adjusted these settings and it still does not work go to the Sony Supoort website and enter your laptop model, country, etc, click on find drivers, download your touchpad driver and reinstall it on your computer. This may reset your issue and will work. If this also does not work then I am sorry to say that you need a new touchpad or there could be something wrong with your mobo. Cheers.
Dec 30, 2009 | Computers & Internet
My inspiron 1525 has a keyboard problem everytime i am typing it jumps back do you have any idea what's going on?
I've been struggling with this issue as well. I type really fast so I thought i was inadvertantly hitting the touchpad and moving the cursor. Maybe, maybe not. But today I discovered that changing one of the dafault settings for the touchpad has eliminating the jumping cursor trouble and I can type fast again without constantly checking my screen to see which line I'm actually typing in.
Here's what I did: Go to the control panel and the mouse and click on the icon for the touchpad and uncheck the touchpad setting "tap to click"
I also put my speed and sensitivity about in the mid-range. (Another suggestion that didn't work was to make my touchpad less sensitive).
Happy typing!
Feb 23, 2009 | Dell F3534 Touchpad
My touchpad is too sensitive
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, find the "Sensitivity" setting. Try changing this setting to lower the sensitivity of the touch pad to the degree you find acceptable.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
Nov 26, 2008 | GPX D1816 DVD Player
Acer Aspire 5100 Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
