Question about Kenmore 24032\24036 Top Load Washer
Washer will not drain
I have a kenmore calypso washer that will not drain. It does everything else but drain. When I close the led it spins but not drain. I check the hose in the back and I don't see anything. can you please help... thank you
    Problem Solver:
  • 6 Answers
You have the most common calypso problem. somethin in the pump.. Pop the top of the washer by inserting a putty knife near each end of front top. it will fold back like the hood of your car. then you can take the front off. the pump is on the right side.
Posted on Mar 03, 2008
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer water will not drain
Check for a kinked or clogged drain line. The hose can be removed from the pump and the pump can be checked for clogs. Take a flashlight and look into the suction port of the pump and look for any obstructions (like the occasional stray sock, for example). Also check the pump impeller for broken or missing blades and ensure that the impeller spins freely. If not, the pump is defective. Hope this helped and best wishes.
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
POSSIBLE CAUSES:
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer stuck in extended spin and won't run
If you are not comfortable disconnecting the drained washer from power and water, and tipping it up so you can unscrew the bottom cover to do this, you can order Sears part # 3954702, which is the diagnostic paperwork that lets you run the washer through its paces one step at a time to help isolate problems.
However, the washer usually should have come with this paperwork, secreted in a plastic pouch up towards the top of the washer attached to the outer case way at the top (therefore hard to get to from the top without opening the top and sticking your arm to the inner surface of the outside case to find it).
Use a flashlight to look for it, and if you remove it be careful not to tear it up, and by all means do not lose it!
Jul 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washing machine won't drain
Found the solution on another website:
http://www.associatedcontent.com/article/817667/how_to_clean_the_clogged_pump_of_a.html?singlepage=true&cat=6
Jul 09, 2009 | Kenmore Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
133 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
