Siemens SpeedStream Modem
Problem for Siemens SpeedStream Modem (4100) (SS4100)
4100SS Power Button fails
By slipjoint on Mar 01, 2008
Modem went off one day no lights, so I started looking for answers. Found out if you just lightly tap the power on/off button the modem lights go off and you can turn the switch off and back on, then it works fine. But each time you just touch the on/off button the modem goes off. The modem is 1 year and 4 months old. Just web surfing. Is that a short in the on/off button? Would you replace the modem?
Same Problem
Apr 28, 2008
-   The Siemens SpeedStream 4100 modem has a faulty switch. The modem originally supplied by A T & T on DSL Subscription failed after 15 months. Switch fails to let power stay on when pushed in. Bought a new modem in identical A T & T packaging at Circuit City. This was the identical modem. Switch has failed on this modem in 7 months. Circuit City only guarantees for 30 days. A T & T refuses to honor warranty because I did not purchase it from them. I've spent literally hours trying to find a contact at Siemems to find out if they will stand behind the product. Anyone know how to contact Siemens on this problem?-   Guest
Apr 09, 2008
-   My button is doing the on/off thing. Out of warranty. Leave it on until it burns out completely?
-   Guest
Mar 31, 2008
-   Same problem: power button is VERY finicky, seems to need the "Fonzerelli touch" to get it to come on and stay on. Ours is about 15 months old and use is moderate.-   Guest
Mar 24, 2008
-   My modem doesn't come back on at all anymore. We were just switching it off and then on again and it would come back on, but now, it seems that the on / off button is just burned out or something. It won't come on. Will Siemens replace the modem?-   a lawson
Best Solution
posted on Apr 23, 2008
Very Helpful)
One Piece
Rank: Guru
Rating: 92%, 75 votes
most companies give a warranty or modem replacement if it's within a year old. contact your ISP & check if they can replace it or give you a new discounted one. also, try using newer or latest modem versions.
Was this helpful?
Yes
No
Solution #2
posted on Jan 25, 2009
Very Helpful)
l33tgoof
Rank: Apprentice
Rating: 100%, 1 votes
I also had this problem with the 4100. This is what I did as a "Lo-Tech" fix. If you push in your power button and hold it in, and your modem powers on, then this should work for you. First unplug all cords. Turn the modem over and remove the small phillips screw from the bottom. Next, gently pry apart the two halves of the case. There are 4 tabs total. I found working back to front the best way. After removing the top half, gently pull the circuit board up and out. Now for the magic. Get yourself a twist-tie. Push the button all the way in, and wrap the twist tie around the whole button. Twist it down tight, and put everything back together. You should be good to go. If this doesn't work for you, or holding in the power button doesn't power up your modem, you could try just blobbing some solder over the three pins on the bottom of the board, under the switch. This should bypass the switch completely. Either way, you can cycle your power on and off with the cord instead of the button. Hope this helps!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Siemens SpeedStream Modem
Questions and Unsolved Problems for Siemens SpeedStream Modem
Do you recommend Siemens SpeedStream Modem (4100) (SS4100)?
Answer
Answer
my Siemens speedstream 4100 modem is working properly but the "internet" light (4th light)... (More)
Answer
On my speedstream 4100, the internet light won't come on. I've had wireless access for about 2... (More)
Answer
we still have the internet but when trying to make a call all we hear is static. Siemens gigaset... (More)
Answer
I cant get my siemens speedstream 4100 modem to work with my linksys WRT54Gs2v1
Answer
I have the siemens speed stream 4100 and I can't connect it in windows 7. How could I solve this... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Modem Experts
Top Computer & Laptop Repairmen
in , FL
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
