Question about Dryers
MAYTAG MODEL MDE9706AYW NEEDS REPAIR
MY ELECTRIC DRYER IS ACTING UP AND WILL TURN OF BEFORE CLOTHES ARE DRY. IT HUMS MOMENTARILY WHEN THE START BUTTON IS PUSHED AND THEN RUNS FOR ABOUT 2 MINUTES AND SHUTS DOWN. SOME HEATED ELECTRICAL SMELL IS EVIDENT AT THIS POINT.ATTEMTING TO RESTART IS UNSUCCESSFUL AND WHEN THE DRYER COOLS OFF, I CAN START IT AGAIN BUT IT GOES THROUGH THE SAME PROCESS...WHAT'S GOING ON? HOW CAN I REPAIR IT?
THANKS,
TODD
  • Anonymous Dec 21, 2008
    I have the same problem with same model. Is it worth replacing motor (model is 10 yrs old) or would new purchase be advisable?
    President:
  • Dryers Master
  • 2,651 Answers
Sounds like your motor is overheating, replace motor
Posted on Mar 01, 2008
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a 10 yr old Maytag dryer that has been acting up lately and wonder if anyone can help. I can use the dryer and dry a load of clothes and it work fine. Go to put the next load in the dryer and it...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Maytag Dryers
Start switch hums, does not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Jun 01, 2010 | GE DWSR405EBWW Electric Dryer
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Start button doesn't start the dryer
see if the drum is jammed if not replace the motor
Mar 31, 2009 | Dryers
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Dryers Logo
314 people viewed this question
Top Dryers Experts
