Question about Kenmore 24032\24036 Top Load Washer
Washing machine broken, kenmore model 110.92274100
Tub won't spin during spin cycle......when i flip washer over to look for problems, oil leaked from gear case (??) i assume.....unit purchased in 1992......please advise trouble shooting to fix... washing machine broken, kenmore model 110.92274100....product line wouldnt let me put in correct model #....
  • 3 more comments
  • halj Mar 29, 2008
    My lid switch is not working. Is it possible to bypass the switch by connecting the two wires on the switch?
    Thanks Hal
  • grizwald Mar 30, 2008
    seems like the clutch will not engage. the motor turns but the drum wont spin.
  • Gunmetl May 05, 2008
    Hi Guru could you pls guide me through replacing the gear case. My Kenmore washer model 110 Type 111 does not agitate I could hear the motor running.
    Thanks in advance for your help.
  • ptteklogix Dec 24, 2008
    Can I get the bypass the lid switch instrustions? my lid switch /lock broke, cant get a new one anytime soon.
  • deberry3030 Apr 14, 2009
    the gearcase oil can use any kind of gear oil?
  • 5,911 Answers
If the washer does not spin ONLY when it gets to the spin cycle, you may have a broken lid switch. Here' how you can determine if the switch is working properly or not. Open and close the washer lid and listen for a "clicking" sound as the lid opens and closes. If no click is heard, chances are your lid switch has come loose, the lid strike (small plastic piece on the lid that depresses the lid switch contacts when the lid closes), or your lid switch is broken all together. If you make the determination that you need to replace the switch, follow these steps:
First of all, unplug your washer. you'll need to remove the console in order to get to the lid switch. the washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. you will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Now...the oil leaking from the gear case may be an unrelated problem. The gear case IS filled with a honey colored oil. Sometimes they leak. This does not always indicate a problem unless the problem gets progressively worse, or you notice slow spin or no spin related problems. If the amount of oil is a small amount it may not be anything to worry about. However, if you are noticing large puddles, you may need to think about replacing the gear case.
I only mentioned the lid switch first, because this is a simple problem that can often be overlooked, AND appear to be a more significant problem. BOTH components, if bad, can exhibit very similar symptoms. If you check the lid switch and it is working properly, you could very well have a gear case going bad. If you need to replace it, I would recommend replacing the motor coupling as well. Here's a list of part numbers:
Gear case - 3360629R $73.88
Motor Coupling - 285753A $15.49
The parts can be found at searpartsdirect.com under the heading "BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP". You can also find these parts at repairclinic.com. The gear case on the Sears website is a rebuilt one. The gear case at repair clinic is a new one and costs a bit more. Just type in your model number in the search menu and a part index will be available.
If you make the determination that the gear case is bad, I can give you follow-up instructions on how to replace it. It is a simple repair that you can do with a little guidance. You can also save a bunch in added labor costs.
Good Luck and let me know if you have any further questions.
PS Additional part numbers (if needed):
Lid Switch - 285671 $29.99
Lid Strike - 350733 $10.48
These parts are available also at the Sears website under the heading "TOP AND CABINET".
Posted on Mar 01, 2008
I have the same problem as posted on mar 30, 08. seems like the clutch will not engage, the motor turns but the drum won't spin (wash. move). would you give us follow -up instructions for clutch & gear case on how to replace it.
Posted on Jul 27, 2008
My lid switch messed up the other day. This is a common problem from what I understand. I took the old switch out to see that it just came apart. I purchased some Gorilla Super Glue for a total of $2.79 tax included. I applied the glue to the broken switch. I let it setup for a few hours and reinstalled my old swith. I have since washed several loads with no more problems. I saved approximately 20-25 dollars doing this. My machine happend to break at 8pm on Sunday. All stores were closed and needed it fixed right away considering I had a washer filled with water and clothes. It works like new again. Hopefully, I saved you a lot of time and money.
Posted on Aug 22, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Leaking water during spin cycle
Likely the tub seal is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Washing Machines
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Jul 15, 2007 | Kenmore 24032\24036 Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
5,749 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
