Sony Tv The tv doesnt turn on and the power led blinks 4 times.
    Problem Solver:
  • 5 Answers
If this suddenly happened and you also have no sound it probably is a fuse, a cheap part but costs a bit to get fixed, or at least it did for me - $200 plus the $3.42 for the fuse.
Posted on Mar 01, 2008
Hello, I have an issue with a SONY KLV-40BX400, the TV turns on, displays the sony logo and plays the power on sound then turns off and turns on a few times and then doesnt turn at all and
If it is PLASMA TV.....
brandon barnes mentions..there is usually nothing physically wrong with 6 blink tvs..you need to reset the TV using the original remote
Not sure if the fix mentioned below is appropriate for your TV Sony eSupport Electronics Drivers Software
Aug 03, 2016 | Sony Televison & Video
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Sony CRT TV not switching on power on LED keeps blinking
How many times do this standby LED blinks at one time switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty section circuit inside. Count it. If you wish to get more details, check this site. Pull up older posts there. Check this site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony CRT based TVs and all other models are given in detail. Check it and confirm.
Apr 08, 2013 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Powered on and geting off. No display front led is blinking 4 times.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
Apr 29, 2009 | Televison & Video
Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 04, 2009 | Sony KDS-60A2000 60" HDTV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
TV not working
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Jan 20, 2007 | Sony KV-40XBR700 40" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
