How can I add a printer to my router so that it will be wireless
    Master:
  • 377 Answers
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
Posted on Mar 01, 2008
Set up wireless
Wireless Method:
  • Make sure your printer has wireless network adapters or a wireless router.
  • Power on the printer and wireless router.
  • Configure the printer to connect the wireless router.
--Enable the DHCP option on the printer. Obtain the IP address automatically.
--Configure the DHCP server of wireless router. Again, assign the IP address automatically.
  • Verify connectivity. Try doing some test prints. If it doesn't work, check the IP addresses.
Network Method:
  • Assign the printer to a wireless network. Go to "Start" and click on "Devices and Printers."
  • Click on "Add a printer".
  • Click on "Add a network, wireless or Bluetooth printer."
  • Select the wireless printer from the list. Click "Next."
  • Allow Windows to successfully connect the printer. Again, click "Next."
  • Click "Finish" to complete the process. If you have multiple printers on your network, set this one as the default. Verify the connection by clicking "Print a test page."
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 14, 2013 | Canon PIXMA MG4220 Wireless InkJet MFC /...
Installing SMCBR14UP printer with wireless connection
Let say you had Win7 then just select "add a printer" after look for 'devices and printer" in the Start section.If you find a printer there just delete it and then "add a printer" and follow the wizard.Note thta it will be wireless so try the IP you use in the Mac PC.
Jun 17, 2012 | SMC Barricade SMCBR14UP Router
How do I add a printer to my wireless network?
You would have to install a wireless print server, like a Netgear WGPS606... It has USB ports that you would connect your printer to... You could actually replace your current wireless router with this one or chain one with the other!! Or your other option would be to buy something like a TRENDnet TEW-P1UG wireless USB2.0 print server, with this you can make use of the router you have now... But either way they basically cost the same! Hope this helps!!
--Joshua79
Apr 05, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless printing
Check the printer's manual if the software of this printer already supports winVista. If it is, you may connect the printer directly to the PC and check if you'll be able to print.
Hope this helps!
Nov 12, 2008 | Compex NetPassage 28G Wireless Router...
Asus WL-500W USB printer - Can't add printer
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
May 12, 2008 | ASUS WL-500W Router (WL500W)
Have router and want to add my 3in1 printer to my laptop,
You will have to add a print server to your printer. The best one for your router and printer would be the D-Link RangeBooster G™ Multifunction Print Server (DPR-1260)
Jan 10, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
About adding ptinter
no issues first configure the ROUTER DHCP>and the printer have a ether net port-RJ-45 jack>so run a CAT-5 cable from printer to one of the ether net jack on the router if teh printer is wire less then configure w/l on the router the mode is mixed>and configure the printer like the way and reboot rate me solved if its helped or more info let me know
Oct 23, 2007 | Linksys Wireless-G RVS4000 Router
Computers & Internet Logo
David Payne
David Payne
