Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
HP zv6000 battery problem
My mom and I each bought an HP zv6000 configure-your-own laptop a bit over two years ago. The only difference between them is that her processor is a bit faster (hers is the 3500+ and mine is the 3200+; I can give all the deets but I don't think you'll need them).
Nearly a month ago, Mom unplugged her laptop to move it and it immediately died (as though there were no battery installed at all). She tried removing and reinserting the battery, switching to a new outlet, and, finally, using my power cord instead of hers. Nothing worked. She then ordered a new battery (it is HP-branded and new, though she bought it on eBay).
While we were waiting for it to arrive, I suddenly began having the same problem with my computer, nearly three weeks later! I had never had a problem with it before, though the battery life has diminished drastically in the past few months. We figured it was just time for a new battery for me, too, but I waited until hers came to decide whether to order it from the same seller.
When the battery arrived, she installed it--but the battery information screen showed a battery icon with a red X through it, and a battery life of "0." She left it to charge overnight, but it did not charge. We then put the battery into my laptop. It showed the same thing, but added "charging" next to the battery, for a short time. Then that disappeared and the battery did not charge. Unplugging the laptops with the new battery installed yields the same result as before--the computer turns off immediately. Both old batteries and the new battery make the "charging" light on both laptops come on briefly when first installed, but then they go off and no charging occurs.
I would think was a problem with her laptop no longer recognizing the presence of a battery and therefore neither charging it nor using it for power, but that mine began doing the same thing after hers did. Is this just coincidence? What do we do now?
I'd appreciate any help you can give. Sorry for the length of this!
  • 6 more comments
  • jtv7220 Mar 04, 2008
    I've got the same exact issue with a HP Pavilion zd8000? Has anyone come across this and more importantly discovered a cause/solution?
  • bardolator Mar 11, 2008
    Yes, we can run them both without battery packs; that's the first thing we tried after switching batteries. :) BUT--we're still not sure whether it's the batteries that are bad or whether the computers aren't "recognizing" and charging the batteries. This is an issue because the replacement battery she bought didn't charge in either of our computers.
    They're both out of warranty, alas. :(
    (Thanks for any help!)
  • bardolator Mar 12, 2008
    Supposedly the battery was new (she didn't get it from HP). These days, how can you ever really know? :(
    She contacted HP, explained the situation, and asked if there was a way to check whether the system was a) recognizing a battery and b) charging. Once they found out that the computers weren't under warranty, they wanted us to send them both in to the tune of big bucks. I understand that they're not going to support a machine that's out of warranty, BUT as the question she asked was a fairly general one that didn't require their mad troubleshooting skills, I'd think HP would tell her whether there's a test for that sort of thing, or a diagnostic you can run from the installed support software, etc. Dell used to be FANTASTIC about that back in the day; my desktop was out of warranty but, not only did they answer my general question, they talked me through the solution step by step (even knowing it was out of warranty). I hear they've changed, as well, though. It would be nice to find a company that believed in its products enough that they'd offer REAL customer service. If I could find a company like that, I'd probably find the manufacturer of my next computer--
  • chefst Apr 17, 2008
    Almost same problem. Wife was on computer, screen flashed message 'going into hibernation". Shut down, will not restart. Blue battery indicator blinks when battery is in and power button is held, nothing when battery is out & power cord is plugged in. Green light is on ,on power adapter. Can the power cord be tested to see if it is operating correctly? Same HP zv6000 about 2 years old.
  • mewaste Oct 10, 2008
    Exact same problem.  I would try buying a new battery, but it seems that may not do me any good.
  • Anonymous Dec 14, 2008
    my zv6000 after two years is now my internet machine only, it wont hold a charge however werks fine pluged in, so I have after lots of research decided that the product i bought was total waste of a grand.... however i use a crossover cabel and basically my desktop never sees the internet now! so if I get some funky virus its on this peice of **** hp laptop that every 2 ms I have to take apart and clean out the heatsinks and fans just so the core stays below 70c But it works great as an additional pc to a desktop system, lol
  • mike0326us Jan 28, 2009
    Where are the batteries in HP DV1000 laptop located? I cannot find where they are.
  • bardolator Apr 01, 2009
    ^^ Thanks, seeandy, but we bought SEVERAL new batteries and nothing worked.
    My solution?  I bought a Mac with an AppleCare warranty.  At least they're standing behind their product so far (and I can take it in to an authorized repair shop locally instead of sending it in)....
I am having the same problem when the power cord is plugged directly to the computer - power light flashes - once battery is dead so is the computer. I have a docking station that plugs into the big port on the right side - that still works and does charge the battery. The thing that sucks is once the battery dies - I am back to the docking station. At least you could use the computer as a "Desktop" before shelling out a grand for another laptop! You can pick up a docking station pretty cheap.
Posted on Jun 19, 2008
    Genius:
  • 3,587 Answers
Try this...can you run them without batteries, just on power from the power pack? that will tell us if those are the culprits?
and in meantime, check your warranty status for FREE here
Posted on Mar 11, 2008
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I bought an HP Pavillion zv6000 on Ebay and the keyboard is not working. It is a used laptop. HOPEFULLY SOMEONE CAN HELP ME
hello
PN494AV is the part number -- please verify this on the baclk of your notebook
BOTTOM OF PAGE IS A VIDEO ON HOW TO DO THIS --
if so, the keyboard (US English) p/n 383664-001 . This is for HP Pavilion zv6000 (PN494AV) CTO FF Notebook . call LAPTOP PARTS, phone [949]-878-9501, USA they have it for about $20-$30
i would suggest getting this notebook to a qualified technician. Otherwise, if you think you are bale to replace it (it's fairly simple), save some money and DIY (do it yourself) .
here are the instructions HOW TO Remove the keyboard
first shut down system, unplu power cord, remove the battery from compartment
In the battery compartment you'll find three screws securing the HP Pavilion zv6000 keyboard to the laptop base. Remove these three screws.
Carefully lift up the top side of the keyboard as it shown on the picture below. There are small plastic latches securing the keyboard on both side but they should't be a problem. Do not lift up the keyboard too much, it's still connected to the motherboard.
Set the keyboard so you can access the cable connector underneath. You'll have to unlock the connector before you can release the cable and remove the keyboard.
Carefully lift up the keyboard. Disconnect the keyboard from the motherboard . remove old keyboard and replace with the one you bought.
WARNING! Be very careful with the connector. Lift the tab, as it releases the connection. You cannot replace the connector if you accidentally break it. The connector is permanently attached to the motherboard. If it's broken, the whole motherboard has to be replaced.
here is a video for a DV6000 series, same concept -- to give you the idea on how it's done
http://www.youtube.com/watch?v=RblDBWRFB7o
please rate me 4 thumbs up
Dec 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hi guys, i bought one a year ago, and just got it
Hi!
If your 220 is in portable configuration (runs on 8 'AA' batteries) make sure that the batteries are 1.5 volts and not 1.2 or 1.3 volts. (1.2V times 8 batteries is only 9.6V)
Also check the battery compartment as we see leakage from some batteries which corrodes the connector plates that the batteries hook up to.
One more thing...check to see that the power cord is plugged into the unit with the notch in the plug pointing UP. The rubber plug housing on the sounder allows the cord to be plugged in backwards if it's forced a litlle bit.
Best of luck!
Mike
Sep 26, 2009 | Humminbird Piranhamax 220 Fishfinder
Hp pavilion zv6000 wont recognize dvd+r
Hi Terry,
The answer is pretty simple, the ZV series is about 4 years old, back then DVD manufacturers decided which formats they would support as it was too expensive to make desktop drives, let alone, laptop drives that supported all formats. That drive only works with DVD-R and I believe DVD-RW. If you want to burn other formats, the laptop will only support them if you add an external drive of a newer make.
Note: Virtually all current models support ALL DVD formats and many support BluRay as well.
Hope this helps,
Chris
Jul 07, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
I bought replacement hinges for my laptop and need help to instal
You can find the instruction on the link below
http://www.instructables.com/id/How-to-Take-Apart-a-Laptop/
Mar 29, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hp pavilion zv5000
It is most likely a motherboard problem. You would have to take it to a service center for diagnostics. If it is the problem it may be time for a new laptop
Mar 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
2,094 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
