Question about Miele S184 Powerhouse Bagged Upright Vacuum
Beater Bar I can't get the beater bar to stop...any suggestions?
    President:
  • 1,673 Answers
Something may have come apart under the nozzle cover, you will have to take the cover off to see. Including a picture, maybe it will help.
Posted on Mar 03, 2008
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
EwingElect
  • 276 Answers
SOURCE: beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Posted on Mar 22, 2009
Vac Belts
  • 701 Answers
SOURCE: The beater bar on my Dyson won't turn. The vacuum
The belt doesn't have to be broken to make the vacuum not work correctly. If the belt is stretched the vacuum won't operate the way it is supposed to. You can get replacement Dyson Belts here:
Dyson Replacement Belts
Posted on Dec 06, 2009
BElectric
  • 1140 Answers
SOURCE: I ran my vacuum against
There is a switch next to the main power switch on the handle which turns the brushbar on and off. When the beater bar becomes obstructed as in your case, there is a safety feature which cuts power to the beater bar. All that needs to be done in most cases is to turn this switch off and back on again and the beater bar should resume operation.
The beater bar on / off / reset switch is the yellow switch to the left of the main power button if you are standing in front of the hoover:
Reset the beater bar and you should be back up and running.
If you have already done this or it doesn't solve your problem, please post back for further assistance.
PLEASE NOTE: This reset method is for the Dyson DC17 ANIMAL as stated above. If you have a different version of the DC17, please post back for alternative instructions and state which version of DC17 you have.
Hope this helps.
Regards,
BElectric
Posted on Dec 14, 2010
Ironfist109
  • 3018 Answers
SOURCE: beater bar does not spin...
  • If the brush bar is not spinning on your vacuum there are a couple possibilities here.
  1. The first thing to check the the belt than connects between the brush bar and the brush bar motor. If it has broke or is very loos then there will be no rotation in from the brush bar. If you hear the motor whirring but no brush bar then the belt has moved to the top of the list.
  • Of course you want to make sure that the brush bar spins freely. Make sure the vacuum is unplugged and give it a few manual turns to make sure there are no hangups. Keep the brush bar of hair and things that get caught in the brush.
  • Another issue is the motor could be burned up or otherwise not spinning. If the motor is not running there is nothing to spin the brush bar. I will upload all 3 exploded diagrams of your vacuum so you can get a good view of your vacuums workings in my next post to you that I will send directly. Mean while here is my solution to your problem.
  • If you have any comments please feel free to leave them right here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 15, 2011
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
How do yu change the belt
Hello. W/D here.
On the baseplate that surrounds the beater bar, you'll see three large plastic screw heads. Turn these and youll feel the plate loosen. Raise the plate from back to front; it hinges toward the front. This gives you access to the beater bar. Remove the beater bar, making mental note as to how it comes out. You want to pay attention to the ends so you can get it back in easily. Remove whatever remains of the old belt. While you have it opened this far, inspect the suction cavity behind the beater bar; this is where they are most likely to stop up over time. Also take a moment to inspect the beater bar and remove the things that tend to wind up on the bar and at the ends. Slip your new belt over the motor shaft, and then slip the beater back under the belt. It will be tighter going back with the new belt. While the belt is on the motor shaft and the beater bar, slide the beater bar back into the sockets of the vacuum, and replace the base plate.
That's all there is to it!
Best regards, --W/D--
Aug 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Beater bar motor will not engage
Mar 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Miele S184 Powerhouse Bagged Upright Vacuum Logo
180 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
