Question about Epson Stylus C48 InkJet Printer
THE GREEN AND RED LIGHT KEEPS FLASHING ON MY EPSON C48
HELLO I AM ANTONY
Last night I finished printing an item off on computer when the
green and red lights started flashing..
Well the thing about it I only use the printer if I have too..
It's only just turned 3 years old...
I come from Havant Uk..
Please can you have because it's driving me crackers seeing
it's only 3 years old . Many Thanks
  • Snowy Joe 1 Aug 10, 2008
    Hi
    My Epson Stylus C48 Printer Say Service Requied And The Green And Red Light Keep Flashing. Does Any One Know What To Do ? It Three Years Old Aswell. I'm A Bit Stuck For Time As Well !! Many Thanks
  • Anonymous Nov 30, 2008
    Printer states that parts need sevicing, this is expensive and last time I purchased another printer from Epsom, I understand there is a programme that will reset the counters, does anyone know what this is and how to use it.
    George
The C48 firmware counts the number f dribbles sent to a waste ink area somewhere in the printer. The printer dribbles every time it’s powered up and when the heads are cleaned. When the counter reaches 8300 the printer stops working.
A utility at http://www.ssclg.com/epsone.shtml will reset the ink counter to zero. Cycle the printer power that’s it! easy peasy. Take care though.. the ink thingy might overflow onto the carpet one day…..
NB. I don’t think that this utility runs under Vista.
Posted on May 26, 2008
Epson stylus c48 blurred print
kindly replace the print cartridge.your problem will solved
Aug 30, 2012 | Epson Stylus C48 InkJet Printer
Epson stylus c48 paper not loaded correctly error
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Oct 25, 2017 | Epson Stylus C48 InkJet Printer
Installed new colour inks on Epson stylus C48 and printer will not respond red light keeps flashing
hewlett packard c48 printer had a piece of paper stuck in it pulled it out, now paper goes through but print head does not print any suggestions
Oct 04, 2010 | Epson Stylus C48 InkJet Printer
Epson c48 red and green lights flashing and not printing
hi c48 cartridge changed ,paper checked static red light on but no one is at home
regards john
Dec 04, 2009 | Epson Stylus C48 InkJet Printer
Epson c48 printer
Reset your counter back to zero. But for some you must also check the waste bin status. Need disassembling this is to ensure ink will not overflow from your printer.
Reseting is only software base. Try this link
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
Post again if you cannot still got it.
May 31, 2009 | Apple Epson Stylus Color 777i InkJet...
Epson c48 printer
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Apple Epson Stylus Color 777i InkJet...
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson c48 printer
you have to change the Head
or try to Reflashe it ok my dear
SALAM with u iLyes Bouhzila
Mar 18, 2008 | Epson Stylus C48 InkJet Printer
Epson C48 inkjet printer flashing lights
I can tell you how to fix this if anyone is interested - report back if so.
Jan 13, 2008 | Epson Stylus C48 InkJet Printer
Epson Stylus C48 InkJet Printer Logo
713 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
