Rexel rdx1750 shredder jam
The shredder got jammed with wet paper and the feed slot was full of compacted dry paper when I inherited it. I cleaned out the slot and got as much of the compacted paper out as I could. However the rubberised area just above the shredding spindles doesn't open when you feed paper in. The sensor works, as the pap[er is fed in the shredder starts to operate but the paper can't get past the 'closed' rubberised area just below the slot sensor. Any ideas?
Heather
  • Anonymous Mar 26, 2014
    Stops feeding after one sheet.
Hjblsadhbn
Posted on Aug 10, 2010
    Scholar:
  • 102 Answers
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
Rexel shredder
Spray with WD-40 or similar lubricant/release agent and let it soak for a while, the remove anything that's jamming the sensor with tweezers and switch the unit on and keep cycling between auto and reverse for a minute or two until unit gets unjammed. Then to reduce friction and to protect the blades use some oil in the feed opening, especially after using WD-40 Good luck
Oct 01, 2013 | Office Equipment & Supplies
Led sensors on the bottom
superflykitt:
Disconnect the power cable and remove the cutter head from the top of the paper bin. Turn the shredder head upside-down and remove the screws holding the shredder head cowling together. Open the cowling and you will see the slot where the sensor fits (on one side of the paper feed slot bottom side.
Aug 29, 2012 | Fellowes FS5 Shredder
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
Paper jammed between blades
it must be a switch that percive papers. just in front of the where you giving paper.
May 29, 2009 | Office Equipment & Supplies
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Back cover is open:
Paper jam:
Memory full:
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
Jan 04, 2008 | Brother HL-2040 Laser Printer
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
1,109 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
