Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Brush won't turn even though belt is fine - Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
  • 372 Answers
Hi.
Ensure drive selector knob is not stuck on park or stop when you lower handle to vacuum if it is pull handle back & turn knob by hand to drive position.
If you have done all this & still have no brush rotation then one of the clutch belts have snapped.
The clutch has 2 belts one you can see going around the brush & the other you cant see which goes clutch to motor.
To replace remove clutch unit then replace both belts is not easy to explain so go to this site http://dysonmanuals.llc.nu/
It has dyson service manuals covering lots of repairs you can do at home.
Chris..
Posted on Mar 02, 2008
ukvacfan
  • 328 Answers
SOURCE: belt not turning
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Posted on Apr 19, 2008
  • 16 Answers
SOURCE: rotating brushes will not turn
remove the lift off and assure the plugs are clear.. reseat... no dice.
then motor... common issue is just not seated right..
Posted on Dec 19, 2008
  • 7 Answers
SOURCE: Altima brush not spinning even after replacing with new belt
idk lol
Posted on Aug 09, 2009
BIKER T
  • 909 Answers
SOURCE: BRUSHES ARE NOT TURNING EVEN THOUGH THE BELT IS ON
you have a belt which attaches from the motor to the brushes. it has broken. open up from the bottom to gain access.
Posted on Sep 14, 2009
Dysonteam
  • 167 Answers
SOURCE: My Dyson vacuum brush does not rotate even though the
Hi its Darran at Dyson.
Please contact our Helpline on 1866MYDYSON as it sounds as though we may need to arrange for the machine to be repaired. One of our advisors will be able to run through some checks over the phone with you so please ensure you have your machine with you when calling.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
Belt is intact but brush won't turn
Even though the belt is intact it can still be stretched or worn and will not turn the brush on the carpet. Here are the belts you need:
Dirt Devil Featherlite Belt
Apr 07, 2010 | Dirt Devil M085850 Featherlite Bagless...
Brush won't turn, belts intact
even though the belt is intact it can still be stretched and not turn the brush. You can get replacement belts here:
www.vacbelts.com
Dec 25, 2009 | Hoover U5753-900 WindTunnel Bagless...
www.vacbelts.com
Dec 25, 2009 | Vacuums
Brush not working??? Belt is fine.
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar...
Jim
Nov 27, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Brush won't turn
Even though the belt is still in tact, that doesn't mean that it is still good. The belt needs to be replaced with a new one because it is stretched. It is probably slipping on the beater bar.
Jim
Nov 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater brush does not work. Brush is clean and belt is not broke. Dyson 07 animal vaccum
Even though the belt may not be broken it might be stretched and if that is the case it will not turn the brush. You can get replacement belts here:
Dyson DC07 Replacement Belts
Nov 16, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Belt not turning
Mar 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
121 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
