Question about RCA F36444 36" TV
No power i can push the on off button nothing happens. there is power at the wall plug
  • joezap01 Mar 01, 2008
    after making what repairs????????
    Master:
  • 377 Answers
After you make repairs you can remove the 4A AC fuse and jumper a 150W light bulb across it. When set is turned on and no shorts are present, the bulb will glow. If it comes on bright, immediately turn off TV. More work needs to be done. If when Negative lead of VOM is connected to TP3 and the Positive lead to TP7 and with Plug P108 unplugged from power supply panel you have a low ohms reading, be sure to check D20 with one side lifted out of board. It is in series with a small RF choke and will read shorted if not unsoldered.
Posted on Mar 01, 2008
  • pincer
    pincer Mar 02, 2008
    On the power supply:
    You have the PTV325 chassis and uses the APW009B002 Power supply.
  • pincer
    pincer Mar 02, 2008
    On the power supply the APW009B002 Power supply.
How to turn on
-Make sure power cord is plug very good into the printer.
-Make sure Plug to outlet and make sure there is power there.
Try again.
Good luck
Mai
Dec 05, 2017 | HP Computers & Internet
When plugged in to mains nothing happens
plugged into mains as in plugged into power in wall? since we don't have a model number can you check to see if there's a power switch or button on the back of that drive?
May 21, 2012 | Computers & Internet
I plugged up my printer and tried to turn it on but nothing happened
1.) Make sure the power cord is secured in the printer and the wall outlet confirmed working
2.) if no lights or antyhing on the screen after pushing the power button then unplug from wall and try again. If still nothing then it is a hardware issue and needs to be serviced at a service center.
Mar 03, 2011 | Brother MFC-290C Multifunction Color...
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Today i went to turn on my receiver and the standby light is on, but wheni push the power button nothing happens.
Try to unplug the AC cable from the wall for a couple of minutes, in order to clear any trouble program. Then plug in AC cable again, with power button off, and press power on in receiver. Do not attempt to use remote for a while. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Audio Players & Recorders
HP PhotoSmart C4180 All-in-One... Problem:
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
Defective power button?
Is there power in your wall outlet, try something else there. Next try the fuse in your washer plug, may have blown.
Dont forget to rate.......
Nov 12, 2007 | Fisher Paykel EcoSmart GWL15
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
I cant get it to even turn on
remove battery and use it off A/C power adapter, mine only works this way, maybe shorted battery.
Jun 28, 2007 | iRiver PMC-120 Digital Media Player
RCA F36444 36" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
