Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg tromm front load dryer dlg5988w
My LG Tromm front load dryer is not using hot air. On the sensor paid its say cooling no matter which buttons i press
  • 7 more comments
  • Anonymous Sep 15, 2008
    my dryer takes 4-5 cycles to dry clothes-dryer does not feel like it's getting hot at all--please help
  • tpmullett Nov 11, 2008
    Same problem. "Cooling" light stays on all the time. It now takes 2 cycles for clothes to dry
  • Anonymous Jan 22, 2009
    Same problem.  Annoying as heck.
  • Anonymous Feb 07, 2009
    why does it say cooling and won't heat up
  • theashes Mar 20, 2009
    exact same problem, cooling light always on.   I Always use manual because sensor shuts off when clothes are still wet, but even doing it manual it takes over an hour.  Serviced it twice nobody seems to think anything is wrong with it!  I hate this dryer!!!
  • Bunnarith Mar 22, 2009
    I have the same problem. My Dryer (DLG5988W) does not dry my cloth. And My Washer is smelly. I stop using them. We have been going to Laundry for the last several months. And my cloth smell good and cost me less than using my own LG dryer.
    I paid about $2100 for both dry and wash. These machine are junk. I will never buy anything with LG brand name.
  • Anonymous Apr 05, 2009
    Exact same problems... smelly washer and cooling sensor on the dryer, clothes take at least two cycles if not more
  • Anonymous Mar 14, 2014
    I have a Tromm WM2455HG sometimes when I push the power button the lights will flash sometimes they don't and I can here a click could this be the control board?
  • Anonymous Mar 19, 2014
    Dryer will not heat up. Have reset the circuit breaker several times.
  • 4 Answers
Dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
  • Glenn Westbrook
    Glenn Westbrook Mar 19, 2014
    Where would these fuses/circuit breakers be located?
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
My lg tromm front load washer stops at 37 minutes
check the drainage pump or electronic board is faulty
Oct 20, 2014 | LG Tromm Front Load Washer And Dryer Set
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm dlg5988w dryer won't heat. I am trying to reset the heat sensor but can't find it. I have removed the front cover but not sure exactly what I'm looking for.
Make sure you have 240 Volts going to the dryer. The motor runs on 120 Volts, but the element needs 240 Volts. If that checks out, you would need to trace the wiring using the wiring schematic. That could be fun.
Aug 09, 2011 | Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Where can I get an online manual for my lg tromm wm2277hw and my dlg5988w?
You can go to diplodocs.com. You can do a search for both of them there. If they don't have them, it has links to other sites to help you find them. Hope this helps you.
Oct 28, 2009 | LG WM-2277HW Front Load Washer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Washing Machines Logo
2,498 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
