2 inch crack in shower pan fiberglass floor
Fiberglass shower pan floor
  • kj1952 Mar 01, 2008
    there was no category for the guestion I need help with
I repair such fiberglass shower pan liners in the Philadelphia > NYC corridor. Generally, this fix should cost you between $150 and $500 depending on the size of the shower and how many people in your area do fiberglassing. I would strongly suggest having the entire shower basin re-fiberglassed as opposed to trying to patch the hole. However, a good fiberglasser should be able to fix this in a couple of hours for a few hundred bucks. If you are in our area, visit www.CFINJ.com and contact us. Brian
Posted on Mar 01, 2008
How to reinforce a flexing fiberglass shower floor
either replace with a precast concrete shower base or fill the area underneath the fibreglass shower with expanding foam. You would have to put a small box section around the drain for access.
May 20, 2016 | Home
Maax shower base installation
I would just cut enough to install the pan by the way does the drain line hook to this pan? that will give it support as wwell
Apr 30, 2014 | Plumbing
Shower leak due to soft pan, bad support
The best way to repair is to completely remove the shower surround and pan. Build a better support and repair the drain then reinstall. Leaking water will ultimately ruin the actual floor of the camper.
Feb 23, 2014 | Forest River 2012 Rockwood Windjammer...
Can't get the plastic anchors in the shower wall. I drilled a 5/16 inch hole in fiberglass but How do you get this plastic threw that hole?
If you are using the cone shaped anchors and you're sure you have the right size hole drilled then just use a small hammer to tap them into place so that small flange on the front rim of the anchor is back tight against the shower wall.When you are tightening screws in be careful to not overtighten or you will cause anchors to slip . Hope this helps. Thank you
Jan 03, 2011 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Small crack in shower tray can i get a repair kit
Are you talking about the shower pan as in the part of the shower which you stand on? It is possible that you might be able to fiberglass the crack depending on the type of material which the shower pan (tray) is made of. Check with your local Home Depot for a fiberglass kit. Good Luck
Dec 02, 2010 | Home
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 | Plumbing
Shower/tub unit does not fit tight at back of unit and if you step in to tub it skeeks
You have a fiberglass tub with tub surround that clamps together and gets screwed in at the top and sides? Did you shim the feet on the floor? Or just rely on the clips that hold it against the wall? If you can still access to the floor, shim everything up, tight, glue in place, then caulk the tub joints, don't caulk it unless you shim it because I don't think it'll work good. you can try it. But,,,,,, hope this helps.
May 19, 2010 | Home
Cast-iorn tub to fiberglass shower kit not sealing
keep caulking or change to ceramic tile, or one piece shower units ,without seams
Mar 03, 2010 | Home
Older shower stall with crack in floor
yes go aout zone and pick up a fibber glass repair kit or some 30 min epoxy
either one of thesr will fix it
the floor will will have too be sanded before appling and after its set up
Mar 29, 2009 | NRS Jones Stephens Corp. S01-050 Shower...
Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Dec 17, 2008 | Grohe Home
Washing Machines Logo
419 people viewed this question
Top Washing Machines Experts
