Question about Samsung HP-R5072 50 in. Plasma HDTV
Sound Issues on a Mitsubishi big screen...
I have recently been having problems with the sound on my TV. There is a feedback type sound when watching the cable. It hums almost to the point that it drowns out the actual sound of the program. The problem doesn't exist when watching DVD's or anything else and I even unplugged everything but the cable. It only seems to be a problem when watching cable. I have connected my surround sound sytem and changed to shielded cables.. I have the same problem on a Samsung plasma. I tried bypassing the surge protector to no avail, so it doesn't seem to be the problem. Switching cables didn't help. I ran the Time Warner cable line directly to the tv, bypassing the tivo, but still have the hum. I'd pay good money to fix this annoying problem.
    Brigadier General:
  • 3,614 Answers
There could be a problem on your cable TV signal, try to re-program the channel again to get the clear reception for viewing, if your unable to do so, you may call your cable network provider to assist you make the channeling of your TV.
It's also thier duty to serve you bc you got bad receptions signal.
Posted on Mar 01, 2008
My RCA big screen tv sound shuts off
This could be several different problems. You could have loose solder joints, bad capacitors, or the aodio ouput IC could be getting hot andf failing and needs to be replaced.
Jan 10, 2010 | RCA P61310 TV
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
TV will not turn off
Wow.. How is the TV plugged in? I had someone with a Samsung DLP do this but hers was plugged into the cable box that was plugged into the surround sound receiver which was plugged into a back up which was finally plugged into the wall. Feedback caused an electrical feedback causing really really odd tendencies.
Second, that connetion between panel and set has a row if pins make sure the second one is not bent because it could be on permanently or causing it to have a constant connection . It is so hard to explain this hope this helps.
Dec 02, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi big screen tv model vs-5062
HEY DOG-UNLESS YOU ARE GOOD W/VOLTMETERS THIS TYPE FAILURE ON THIS MODEL TV CAN BE VERY DIFFICULT.THE BEST ADVICE I CAN GIVE IS CALL A TV TECH EXPERIENCED W/MITSUBUSHI TVS AND GET AN ESTIMATE.
Nov 14, 2007 | Pioneer PRO-200 60" Rear Projection...
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Using a cable box? Bypass it if you have one and see if the issue still exist.
Apr 04, 2007 | Mitsubishi VS-45605 50" Rear Projection...
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
