Question about Microwave Ovens
Sharp microwave runs when door closed
Our microwave (Sharp R-1451) has been running fine for years. Yesterday it has begun to run (makes loud fanlike noise different than oven fan noise), when the door is closed. In addition, the keypad is nonresponsive for the most part. For instance, I have unplugged and can reset the time, but can't set a cook time or Sensor Reheat, etc.
Thank You
  • 1 more comment
  • GymNovice Mar 02, 2008
    OK, so I opened up the panel, discharged the capacitor and looked at the switches figuring they would be cheap enough to replace. I suspect I've found the problem because the top one is loose. It sits on a prong on the upper rear such that when the door is shut the front end swings down and I assume that causes only the partial circuit with the other switch? Can you recommend a way to reattach this switch so that it will not swing?
  • GymNovice Mar 04, 2008
    This was spot on - Adding some epoxy to the lower corner of the switch where it attaches to the front of the panel is able to hold it in place against the door shutting and now it works as before.
    NOTE to others who try this: This Microwave is 10 years old and the reason it broke is that the plastic tab holding the switch broke off from the pressure of the door being shut. I broke at least 3 other little tabs getting the front panel off (1 on the front and 2 on the opposite side) without applying that much pressure! Panel is still a little loose, but that's a problem for another day.
  • kevin luces Jan 03, 2009
    one of the two safety door latches is broken in my dcm24s microwave which sits atop oven. Door won't open- door open button not engaging-trying to open door by inserting L-shaped non-scratching tool.Tight fit of this microwave- tough to pull out- do I need service call - If I get door open- ? epoxy broken latch- does it sound as though I will need a new door opening mechanism-? spring disengaged or whatever.
    Help
    Thanks
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or sometimes a problem on the control panel.
I would suspect the door switch mount has a broken tab allowing the switch to swing down when the door is closed, not allowing it to really be activated.
Also, even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
  • William Miller
    William Miller Mar 02, 2008
    The ideal solution is to replace the switch holder (latch hook or door hook, as it's called) but that is a lot of work and it's critical to get everything aligned properly.
    If you decide to go that route, you can get the part from Tritronics athttp://www.wehaveparts.com
    Other folks (including me) simply use a spot of hot glue or epoxy (JB Weld is best, but 2-part epoxy is fine) to tack the switch in place on the mount.
    But it's critical to make sure everything is squeaky clean and dry before applying the glue and allow it to dry / set for several hours or overnight before reassembling the oven.
    Looking forward to my "FixYa" rating for getting this right on the nose! :)
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Microwave oven runs when door is open, and does not always run.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 27, 2008 | Panasonic NN-C994S Convection/Microwave...
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Jenn-Air Microwave M169B 11 years old.
You should be able to get a replacement keypad, and that's not a hard job for a DIYer.
If you're interested, post your correct brand and model and I'll give you a more specific suggestion.
(Your post subject says Jenn-Air M169B put it's posted under Sharp R-316FS so I'm not sure which you have).
If it's a Jenn-Air, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You can usually find Sharp exploded views by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
Jan 17, 2008 | Sharp R-316FS Microwave Oven
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Sharp Carousel Microwave ESP Sensor R-1451 1.50 w 850wats has load noise and will not heat, what could be wrong?
It's probably a shorted high voltage rectifier diode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at ourlisting here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from the Sears link above or from Tritronics at http://www.wehaveparts.com
If you need more help, please feel free to conact me directly through the links at our site.
Dec 18, 2007 | Microwave Ovens
Microwave Fan Running for 24 hours
Sounds like cycling the power line did it.
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
601 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
