Question about Singer CE-100 Futura Computerized Sewing Machine
Usb cable is connected and machine switch is on
COMPUTER SAYS THAT MACHINE IS NOT ON, AND IT IS,. OR SAYS US B CABLE NOT CONNECTED, AND IT IS
Try this , turn on sewing machine and unplug usb. then turn machine on 1st. and put the usb in a differnt port . It work of me.
you may have reinstall divers.
Posted on Mar 17, 2008
I have a Singer Futura Quartet and when I try to use the embroidery function I get an error message that says my machine is not turned on or the cable needs to be connected. everything is connected
If your computer indicates that there's no USB connection to the machine, and therefore the Futura program refuses to start, there are several possibilities. The most likely is your cable is bad, although I have had USB cables that worked fine elsewhere, but didn't on the machine. Try switching the cable you're using with your printer cable.
Sometimes if you originally installed it using one USB port, it doesn't want to work if another port is used. Although I have not had that problem on this line of Futuras, others have. Try switching the port you're using.
Another possibility is the USB plug on the machine doesn't "seat" very well. That's true of all the Futuras. Make sure that the plug is sitting squarely in the machine. Personally, I tape the plug in using masking tape, then plug and unplug it from the computer side.
Sep 28, 2016 | Singer Sewing Machines
I have a memory craft 12000 and I have installed the software. When I try to send an embroidery design from my PC to the sewing machine I gat a communication error stating that I need to connect the usb...
Suggestion - Your usb cable need to be installed first and recognised by your pc as "your new hardware is ready to be used"
or if not, may need to reinstalled your software ensure your usb cable is connected as well.
Oct 30, 2013 | Janome Sewing Machines
Futura software says machine isnt connected
Go to the Singer website and down load the driver for your machine.
Mar 30, 2013 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce200 usb cable not connected
IF YOUR WINDOWS 7 UPDATED TO 64 BIT, THE SOFTWARE WONT WORK ANYMORE
Dec 31, 2012 | Singer CE-200 Quantum Futura Computerized...
I keep get a connection error. Ck that USB cable is connected and the power switch is on. Each time it comes up. Help
Make sure you have the USB plugged into the back USB ports on a desktop computer and try each of the different ports on a laptop computer. What Singer doesn't tell you (and probably isn't aware of) is that the back ports provide more voltage than the front ones (and is also true of certain ports on your laptop). The USB cable and your computerized sewing machine require more voltage than the other ports allowed.
Give this a try-it should do the trick.
May 01, 2011 | Singer Quantum XL-1000 Computerized Sewing...
I keep getting a connection Error Message. Please Check that USB cable is connected and power switch is turnedl. I just upgraded to a new computer from and older model computer
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
Apr 29, 2011 | Singer CE-200 Quantum Futura Computerized...
I can not get the softward to download and be usable on my newer computer. HELP! I put the software on and I get a window telling me that the USB cable needs to be connected and it is.
Make sure you're plugging the USB cable from the machine into a USB port in the BACK of your computer, not one of the front ports or a port on a USB hub. The cable and machine need more power than most of those ports provide, a technical detail that Singer doesn't realize. Good luck!
Dec 19, 2010 | Singer CE-100 Futura Computerized Sewing...
When I try to open the futura program a pop up box continues to say check that USB cable is attached and machine is turned on. I tried two different USB Cables and turned the machine on. However the same...
My computer is extremely touchy when I use my usb cable to attach to my machine. I have to use the SAME usb port that I used when the driver was installed or else it will not recognize that my machine is plugged in. Basically it is telling you it cannot find your machine. Reinstall the driver and mark which usb port you used to install the machine.
Also, in order to open the futura software, your machine must be powered on and connected via USB cable before you attempt to open the software on your computer.
Oct 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
Mar 02, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
