Gateway 831 GM
I unhooked my computer 5 days ago to move furniture and plugged everything back in today and it will not power up. It does not come on at all. I checked the manual and it show that I plugged in everything correctly. Any ideas?
Thanks
Gary Taylor
  • 1 more comment
  • Anonymous Jul 19, 2008
    same problem- no switch on back - what's a mother to do? unhooked the power to the motherboard and waited - that worked once - what are those green lights about?
  • jplofgren Aug 07, 2008
    Also have a Gateway 831GM computer that will not start up. Completely dead. No fan or external lights, except green light on the back of the power source. Replaced power source ($45.00) at Gateways recommendation, and still nothing. Tried bypassing the switch to make sure the switch was not the problem. Still nothing. Suggestions?
  • aefawfae Jan 11, 2009
    Same problem with mine, too. I checked all connections inside (and swapped in a new power supply), but no luck.
    You disconnected everything inside and put it back together to get it to work?
  • 28 Answers
Make sure that there is not a power switch on the back of your computer. Alot of computers have a power switch on back of the power supply as a master shutoff.
Posted on Mar 01, 2008
I had this problem and i just went inside took everything apart and put it all backtogether and it worked i did notice the power buttons conection plug to the motherboard is very touchy on this motherboard ...
Posted on Aug 29, 2008
Spark plug wire diagram for 1997 gmc k1500 5.7 l
1, 8 4, 3, 6, 5, 7, 2, for as long as GM has made V8's.
Oct 07, 2012 | Worldwide 1997 GMC K1500 Sierra XC 5.7L...
I had a fan making a clicking sound & a Friend cleaned it & now it turns on but nothing on the screen, what is messed up? where can I find parts to fix it? This is on my Gateway 831 Gm it has a...
Hi jdr_dlr519!
Pardon me.... but did your friend connected the monitor cable correctly on the system unit? Cleaning the fan will not break your computer... however, if he forgot to disconnect the power cables before opening the unit, it may do a damage.
Jul 20, 2011 | Gateway 831GM PC Desktop
I just got my laptopm about 4 - 5 days ago . It's
Seeing that that computer is only 4 to 5 days old the best advise i can give you is contact Dell Support or take it back to the store you bought it at and get it replaced.
Jul 10, 2011 | Dell Computers & Internet
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Gateway 831 GM
if the power supply was not the issue try memory,cpu and the motherboard..
Apr 22, 2009 | Computers & Internet
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Nov 30, 2008 | Gateway 831GM PC Desktop
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Computers & Internet Logo
656 people viewed this question
David Payne
David Payne
