Question about Canon CanoScan FB630U Flatbed Scanner
Canon FB630u problem
I have used a Canon FB630u scanner with my laptop for 2 years. Now I get an error code saying... I have a code 19 registry error. I have uninstalled, reinstalled several times, used the fancy uninstaller from Canon, tried to fix/repair my registry, etc., etc. I have 3 registry cleaners, still no luck!!!
Can you help with how to get my registry fixed/cleaned... whatever?
I really appreciate it very much!
Ed Kaeser
Franklin, TN exactly the same issues, tried most of the same stuff and more besides, no luck. Mine is a LiDE70, and the laptop is an HP nc4200 compaq. Scanner is fine on my desktop too! Maybe some law of physics that says canon scanners only work for a year or so on a laptop?
  • Adriannicol Mar 02, 2008
    I just found a fix from
    the HP site for the same problem with an HP scanner - it worked for my
    Canon LiDE70. Run regedit then:
    1. Double-click
      HKEY_LOCAL_MACHINE
      to open the folder in the left pane of the window.
    2. Double-click
      SYSTEM
      CurrentControlSet
      , Control and then
      Class
    3. Select
      {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
      and check in the pane on the right for the
      Lower Filters
      string value.
    4. Right-click
      Lower Filters
      and delete it.
    5. Disconnect the scanning device and restart the computer.
    6. Reconnect the scanning device after the computer is restarted.
    7. BINGO! it worked!
  • 818 Answers
I encountered this site from where you can dowload the driver and application for your printer
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=235&modelid=6853
and i find a small utility that i hope can be help you
http://downloads.zdnet.com/search.aspx?compid=57911
Thanks in advance
Sergio
Posted on Mar 01, 2008
  • Sergio Scalfaro
    Sergio Scalfaro Mar 03, 2008
    i'm happy that you have resolved the problem.
    Great
    Sergio
    Genius:
  • 1,601 Answers
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolution
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Try these options:
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard. Click Uninstall, and then click Scan for hardware changes to load a usable driver. Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true)The registry information applies to Windows XP.
I lost the cd for my canon fb630u and cant to use it ?can you help me
There are plenty of replacement Canon FB630U cables on Amazon.
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=canon+fb630u+scanner+cable&rh=i%3Aaps%2Ck%3Acanon+fb630u+scanner+cable
Jun 13, 2016 | Canon Office Equipment & Supplies
CanoScan FB630U scanner
Use this link to take you to canon download site. Enter your operating system at this canon site. The download is free. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6853
Jun 27, 2009 | Canon CanoScan FB630U Flatbed Scanner
Driver for Scanner
visit canon web site download driver
Identifying correct USB cable for CanoScan FB630U
look at the port on the scanner and look at the cable if they match they should work.
May 24, 2009 | Canon CanoScan FB630U Flatbed Scanner
I lost cd and cant install my canoscan FB630U. i need help tnanks
Here is the Canon link for your model that you need ro download the sofrtware and driver:
Apr 09, 2009 | Canon CanoScan FB630U Flatbed Scanner
Linux compatibility
Karateng83, Have you gone to the Linux download sites to verify if a driver is available for the Canon FB630U? The next thing to do is to go to Canons homepage and if you cannot find anything there, e-mail them with your request. If that fails, go to Sourceforge.com and verify what is available for Linux drivers. they have a search engine.
Sep 15, 2008 | Canon CanoScan FB630U Flatbed Scanner
I have struggled with this same issue for ages, I just found a fix from the HP site for the same problem with an HP scanner - it worked for my Canon LiDE70. Run regedit then:
  1. Double-click HKEY_LOCAL_MACHINE to open the folder in the left pane of the window.
  2. Double-click SYSTEM , CurrentControlSet , Control and then Class .
  3. Select {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and check in the pane on the right for the Lower Filters string value.
  4. Right-click Lower Filters and delete it.
Feb 13, 2008 | Canon CanoScan FB630U Flatbed Scanner
Driver on xp pro 4 Canon CanoScan FB630U Flatbed Scanner
i lost disc to install canoscan FB630U i need to download & install driver
Nov 02, 2007 | Canon CanoScan FB630U Flatbed Scanner
Canon CanoScan FB630U Flatbed Scanner Logo
300 people viewed this question
old marine
old marine
