Is this tv digital ready??
I need to know if this tv is capable of (over the air digital broadcast signals) Thanks!
    Scholar:
  • 133 Answers
Best way to tell is to hookup to rabbit ears or outdoor antenna and run the autoprogram of your channels . If you get any stations with per say 8.1 or 6.2 then you have a digital tuner . If it only shows 8 or 20 no it is just an anolog tuner . You can buy tuner that will switch the broadcast for you . Average cost is $45 to $90 . Good luck
Posted on Mar 01, 2008
Set up installing antenna, tried Ant A & Ant B no receptiom what do I do?
The first question you have to answer is whether your TV is capable of receiving digital broadcasts. TV stations no longer broadcast the "old analog" signals, but now transmit only in digital format. If your TV is not capable of receiving digital broadcasts, you will need to buy a special box which allows you to receive digital broadcasts. Then you would hook it up in the order: antenna -> digital box -> TV.
If your TV is capable of receiving digital broadcasts, I've found that it is very important that your antenna have a pretty much unobstructed view of the direction from which the signal is coming. For instance, if your local signals are broadcast from the southerly direction, you should try to mount your antenna to a window which is facing south.
One last point before I forget, you must make sure that you select the proper input on your tv. For instance, I have cable, and a dvd player hooked up to my tv. Before I use the dvd, I have to go into the TV menu and select my dvd. When I want to return back to cable, I have to go back into the TV menu and select the cable input.
Jun 07, 2015 | Televison & Video
I'm wanting to know if this TV is one that is Digital or analog? Will I need to buy a converter box for it if it isn't hooked up to cable or direct TV? I believe it was purchased in 2006.
No.It is a digital tv.Just require a good digital antenna for a better and a longer ranges for the tvs broadcasting stations incommming signals.After a digital antenna is hook up.When u go in to the tv menu go to Setup.go down to CH. pick AIR and enter and tv should be automatically be scanning for DTV free air broadcasting tvs stations.
Dec 05, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Lcd tv digital tuner
Welcome to the world of off-the-air broadcasting!
First, be sure you have the TV set up correctly and that is in fact capable of digital tuning. Just because a set was sold as HDTV doesn't mean it has a digital tuner. Small TV sets weren't required to have digital tuning until shortly before the switch from analog. This set may require a digital adapter. If the set does have digital tuning, be sure you have "air" selected and not "cable" for your tuning mode. Also let the set scan for channels.
With digital broadcasting, signal strength is critical. In the analog days, a weak signal would give you a fuzzy picture, but you could see something; with digital, a weak signal means you see nothing at all. You may live in an area where the signal is too weak without using an amplified indoor antenna or putting one on the roof. Your location, other structures around and weather conditions all affect digital reception as well. Many people were (and still are) upset to find that they just couldn't get any channels at all once digital broadcasts took over.
I hope this has been helpful. Thanks for using Fixya!
Jan 31, 2010 | Craig Televison & Video
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
Are my Orion tv's purchased in 2002 digital ready
Your TV does not have a digital tuner. You'll need a converter box for digital broadcast reception. Remember that if you're on a cable system or using a satellite receiver, your TV doesn't need to have digital tuning. It's only if you want to watch off-the-air broadcasts that you'll need the converter.
May 12, 2009 | Orion STV2763 27" TV
I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
You have a really nice TV, you have a built in ASTC tuner(digital).
If you want to recieve OTA(over the air) signals, all ypu will need is an antenna.
Visit this site for some great info on digital TV.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if I can provide further assistance
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 16, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Mitsubisi tv CS- 40307 digital capable ?
If you are subscribing to cable or satellite TV, then the answer is no; they will continue to send an analog signal to your TV. However if you are using an antenna to receive your broadcast, then you will need a converter. Broadcast TV (over the air) has switched to a digital signal for most of the channels as of June 12th.
Feb 22, 2009 | Mitsubishi CS-40307 40" TV
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dan
Dec 31, 2008 | GE 35GT740 35" TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
