Question about Vicks V150SG 1 Gallon Humidifier
No steam comes out
The vaporizer seems to be working fine - lights comes on, it hums like it's getting ready for steam to come out - but nothing happens. It's plugged in, there is plenty of water, it's clean, etc. Help!
  • dananddean Jan 19, 2009
    I have the same problem and I tried the salt (as it says to do so in the manual when you first get it) but it still won't work??
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Posted on Mar 07, 2009
    Problem Solver:
Add some table salt to the water! Worked like a charm for me!
Posted on Oct 27, 2008
  • GEORGEFIXER Feb 06, 2011
    The salt trick really works. Just add 1/2 tablespoon of salt to a cup and hot water, then pour it to the reservoir and cheers.
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vicks vaporizor model101 is all limed up and won't steam. The light comes on but no sound or steam. How can I clean it? I can't get it open. I have hard water with lots of lime.
A 50/50 solution of White Vinegar and Water run through the system should clean it up. If it's really bad, you may have to do it twice. Just flush out the solution with claer water, before trying to use the Vaporizer, as it's intended.
In the future, due to high mineral content of your water, use Distilled Water. You can buy it by the gallon very inexpensively at pharmacies and grocery stores.
Feb 17, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is running however there is no steam coming from the machine. Ran all night and used no water does it need cleaned or should i just replace it. thank you
Well, let's consider what we have:
How old is the vaporizer?-- Could the heating coil be all limed up?
Lime-Away, or Vinegar might help clear the Calcium and mineral build up on the heating element-
Or there might be a bad connection?-- Do you have any lights lit?
Open it up, and tell us what you find-
Mack B
Jan 20, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a quiet bubbling/gurgling noise. This is only the second time that I've used it, but I can't seem to find the instruction manual. What could this mean?
That is very normal...the sound is the water being turned to steam which is the "vapor" that comes out...
Everything is okay and perfectly normal.
heatman101
Mar 30, 2010 | Vicks V150 Humidifier
No mist coming out at all
on the box there is a number for questions or comments : 1-800-VAPOR-1-2 ( 1-800-827-6712 ).
Mar 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Not working correctly
Does your humidifier use an ultrasonic transducer for vaporizing the water?
May 08, 2017 | Crane Penguin 1 Gallon Humidifier
Vicks V150SG 1 Gallon Humidifier Logo
2,555 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
