The screeching noise will be a fan that is trying to run and is rubbing. If it were my laptop, i would take it apart carefully and make sure everything is screwed into the correct locations. You can buy small screws from a lot of electrical retailers or places like Maplin or RS in the UK, i dont know anywhere else in the world.
Sorry can't be more help, it might be that it is over heating, so taking it apart and fixing the position of the fan would most likely help. Then while it is apart, make sure everything is screwed in too.
Hi, you have a static problem. i recommend that you remove all covers and try if the problem is still here. next step you should check whether all grounding parts/metal/ are interconnected to allow proper grounding.
you should check near the processpr because most static noise occurs near the processors and heatsink.
