Question about GE JVM1430 Microwave Oven
Fan/Light The fan & range light do not work - is ther an internal fuse?
  • kenburg Sep 24, 2008
    the bulb shorted across the filament and now both lights won't come on.
    everything else works.
    Do I have to remove the microwave from the wall?
    then what do I fix?
    Ken
  • kenburg May 11, 2010
    What goes bad on the board? What do I look for to confirm bad board?
    thanks
  • GE Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
MMV4205AAS no light, no fan...then no power
Well part of what you said does sound correct other parts dont make any sense.. Question one is the unit dead now?? have you checked the outlet for power??
have you checked the internal Line fuse to see if it is good??
Does the unit have power to the control board?? these questions need to be answered before we can move on ..As far as the light issue there could be a bad relay on the ctrl board but kets get the unit up and working first
Jan 31, 2008 | Maytag MMV4205 Microwave Oven
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Over the Range Lights & Fan Failed. GE Microwave Oven JVM172G
It's not a fuse issue.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We see and repair this a lot. The problem is on the control circuit board.
You can have it repaired or replace the smart board yourself.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes. Then...
Some connectors have a lock.
Then you remove the defective board and install the new one in your frame. Be careful, since the display is made of glass.
Jan 29, 2013 | GE SpaceMaker Microwave Ovens
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light bulb located?
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
TO BIGDEEL
Do you mean your internal cooling fan or the hood / vent / exhaust fan?
If it's ther internal cooling fan, do not use the microwave or the magnetron will overheat and be damaged or destroyed.
Jun 23, 2008 | GE JES1288SH Convection/Microwave Oven
No light, internal fan...then no display
The light isn't a safety issue but I would think that the fan would be.
The fan is designed to remove excess heat from unit and keep it cool. Without the fan, you're now operating the unit under conditions that it wasn't designed for.
With the unit unplugged, try removing the cover and see if a fuse has blown. If so, replace it with the EXACT value of the original.
See if the unit powers up again. Try heating heating up something for 30 seconds to see if the Magnetron is still functioning.
If so, check to see if the bulb is good. Did the bulb and fan stop at the same time? If so, it might be something in common that controls both.
Don't operate it further until you have it looked at. You don't want to cause something else to fail.
- Jim
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
GE JVM1430 Microwave Oven Logo
99 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
