Question about Hoover U6434-900 Bagged Upright Vacuum
Can I fix height adjusment?
Height adjust dropped down(?) so even at highest setting roller digs into the pile of a typical height carpet (hard to pull back too). Despite explaining problem twice the recommended authorized repair tech didn't fix, but I was charged $115 for new roller, belts and filters.
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
All i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
Posted on Mar 02, 2008
Reading this blog. Dyson is of little to no help. How disappointing when you spend a small fortune on one of their products. I'm just now experiencing hard to push with. DC25 Animal. Can't adjust height....
sorry to say your dyson is not the fault, its your carpet, a lot of new carpets have a tight weave pattern, this makes it impossible to push any vacuum. all new carpets have a directional pile always vacuum with the pile. The best option is to buy a auto drive kirby it does all he hard work for you. you can pick a refurbished one up for around 300
Aug 12, 2017 | Dyson Vacuums
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
Hey everyone, first time on forums. I have a Eureka True Clean vacuum that I found in the garbage. I have disassembled everything, cleaned and restored it. Looks perfect now. Suction from hose is powerful,...
Change the belt on the unit, and adjust the height adjustment until the brushes are just touching the carpet. I know you mentioned the belt looks good, but when you get the new EXT-U belt, you will notice a size difference. Good luck!
Jan 25, 2012 | Electrolux Vacuums
On my hover U6616-900 the self propell work fine on the med setting on med height carpet, but when I go to low height carpet and height set on med the self propell does not pull the vacuum and it is hard...
This is a typical problem you are describing. I would recommend you change the belts, this will resolve the "hard to push" and most likely resove your issues. based on the s/n given you maching was made on sept 2004.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 24, 2009 | Hoover U6616-900 WindTunnel Bagless...
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Bobbing up and down?
its more than likely the pile of the carpet is a little tighter in some areas of the carpet than it is in others. and, then you have to concider the grain of the carpet. I know your going GRAIN ?? what the ??? and scratching your head but yes even carpet has a grain. mine does the same thing and i have noticed that when i change directions over the same area it will not bob.
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover U6434-900 Bagged Upright Vacuum Logo
818 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
