Question about Brother DCP 115C All-In-One InkJet Printer
I cant to move my DCP-115 to the maintanance mode
I tried to move my DCP-115C to the maintanance mode by press start mono and 4-times arrow up, but the machine it seems blocked.
It means when I press start mono button (blue) the printer gives 3 pip's (3 short noise signals) and for each of 4 press of arrow up button the printer gives 1 pip's signal. Moreover the red "!" leds on the left side od LCD panel is blinking The message on panel is "unable to print - see trouble shooting in the manual". The message was comming when I changed black cartrige on new one and done print test and cleans many times (accordig to print test results). I did't find any part of paper or anything inside printer as it is sugested in manual.
Please help me to solve the problem.
  • 1 more comment
  • mario1n Mar 01, 2008
    THX
    It gives "Machine Error46"
    What can I do with that?
  • jayice Mar 12, 2008
    I too have the unable to clean message,
    then i get MAchine error46
    i this fixable?
  • Anonymous Mar 21, 2008
    I have a similar problem with my Brother DCP 115C which can't seem to get out of the "Unable to clean" or "Error 46" mode.
  • 832 Answers
First button is MENU then start b/k copy then 4x arrow-up....
Posted on Mar 01, 2008
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 195c print problam [black and yellow] punjabi
try to clean the print head 2-3 times,if the problem persist chage the print head
Feb 24, 2011 | Brother DCP 165C Compact Color Inkjet...
Unable to clean
unable to clean mean the waste ink counter need to be reset.. and the porous pad need to be replaced.. to reset ... press the Menu & Mono start keys then next press the up arrow key 4 times to make the machine enter the maintenance mode. Once in, enter 8 & 0 by using the up arrow key & SET keys. then press the mono start key several times untill the purge count appears on the LCD.
Then enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero. Last press the stop/exit key to return to the initial stage of the maintanance mode.
To exit enter 9 twice by using the up arrow & set key's to exit from maintenance mode.
May 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to print 46
This is mainly due to dirty machine. Try following my steps:-
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times untill the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintanance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Aug 14, 2009 | Brother DCP-330C All-In-One InkJet Printer
Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> 3. press the mono start key several times untill the purge count appears
> on the LCD.
> 4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the
> purge count to zero (like in 1)
> 5. press the stop/exit key to return to the initial stage of the
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Mar 06, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C displays unable to init message tried the trouble shooter in manual still says it what should i do
press menu then start b/k-copy (mono) then fortimes arrow up button quickly after another. machine will switch to mainteance mode. press start bk copy.
What two digit error code does the machine display?
Post here again.
Mar 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
I keep getting the message unable to print see trouble shooting in manual
If trying to Print in Word 2003 - 2002 - 2002
Click on tools > options > Print tab > Uncheck Back Ground Printing. Click on ok. Try Printing.
If you are trying to Print from Word 2007.
Click on Office button > Word options > Advanced > Locate Print options and uncheck Backgound Printing click on ok. try Printing
Oct 19, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
1,245 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
