Question about Lexmark C500n Laser Printer
Toner level on Lexmark C500
How can we reset the toner level for this printer cartridges.
  • lenitatara Mar 14, 2008
    My Lexmark c500, turns on, only when im about to print a document out, the error red button comes up.
    Ive checked out the printer, its not a paper jam, ( and it usually says it anyway ) paper is fine, not bended.
  • Kaviraj Ramputty Jun 20, 2008
    Does it print a test page
  • 300 Answers
SOURCE: Lexmark C500 printer SVC LL ERROR, SVC L1 ERROR
As i'm sure you already know the error means - Laser power is lower than the output limit.
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Posted on Aug 11, 2008
SOURCE: TONER CARTRIDGE
Follow these steps (per Samsung Support) to reset cartirdge error:
Press Menu, #, 1934
Screen will read: Ready, Tech Mode
Press Menu until you see Data Setup
Arrow through till you see New Cartridge, enter yes and hit OK or enter
Now re-enter Menu, #, 1934 to get back to Regular Mode
Toner Empty message should be gone!
Good Luck!
Posted on Aug 20, 2008
SOURCE: LEXMARK C500
I found a fix for this! Take the cartridge out. On each side of it there is a hole (I believe that this is a sensor...) place a small piece of electrical tape over these holes. Place cartridge back in.... no more error! But I would go out and get some toner soon though!
Posted on Oct 30, 2008
If you open your printer front and pull out all the toner cartridges, on the left, you will see 4 LED lights vertically in a column that match up with 4 matching red light receptor sensors on the right side. Each toner cartridge has a tiny window on each side. When the toner powder level drops below the window level, a light passes all the way through the cartridge from the LED light to the light receptor and trips the printer to display the low toner warning.
The goal is to BLOCK THE LIGHT. The easiest way is to put electrical tape over the window on the right side of each cartridge window. To ensure you have the proper hole, just shine a flashlight in the hole and you will see the reflection from the tiny plastic window.
Posted on Nov 16, 2008
vegakitten20
  • 685 Answers
SOURCE: Toner Cart chip reset for Ricoh Aficeo sp c400dn
try to unplug it and plug it back in this will reset it
Posted on Jan 04, 2009
Lexmark Z640
Are you using original cartridges?
Mar 09, 2008 | Lexmark Z640 InkJet Printer
Print is blurry
Remove the toner cartridge and print cartridge assembly. Slightly shake it from side to side to redistribute toner properly. Also, please check the supply level of your toner cartridge.
You might want to consider replacing the toner cartridge since you have already replace the PC unit.
Also, check the transfer roll for signs of toner buildup and contamination.
Inspect the HVPS contact (transfer roll) for contamination. Verify the high voltage cable is plugged into the LVPS/HVPS.
If all the steps mentioned above were done. I would suggest you contact Lexmark Technical Support for further assistance.
Apr 04, 2012 | Lexmark E360d Laser Printer
Lexmark optra t610 invalid refill error change cartridge......how do i reset the printer to disable the error
The error may not be specifically a toner cartridge problem but may be due to a stuck cover open switch on the printer. Perhaps this article on Error: "Invalid Toner Cartridge" or "Invalid Refill" will be able to determine the root cause of the problem. Just click on this link: http://bit.ly/dupj2m. Just make sure you are using a genuine Lexmark toner in the printer. If you need further assistance, you can also contact Lexmark technical support. Thanks.
Sep 14, 2010 | Lexmark Optra T614 Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Aug 11, 2008 | Lexmark C510n Laser Printer
Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Jul 02, 2008 | Lexmark Office Equipment & Supplies
LEXMARK C500
Jun 14, 2008 | Lexmark C500n Laser Printer
Lexmark C500n Laser Printer Logo
469 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
