Question about Dishwashers
Soap door won't open during wash cycle
The soap door doesn't open to get the soap into the wash cycle. After the cycle completes the soap door is still closed, or it may be open but the soap packet is still in the dispenser.
Soap dispenser won't open during wash cycle. Once the soap dispenser won't open, the dishwasher stops and all the LED lights blink on the display.
  • 3 more comments
  • mmoore Mar 02, 2008
    We figured it may be the dispenser or the actuator has gone bad--I'm sorry for my ignorance, but what does pcb stand for?
    Thanks so much.
  • angels_35 Apr 20, 2008
    Mine just started doing that. When I googled it I found a site that said not to use powerball in the dishwasher like what is in the electrosol tablets. We are on our second box of using them, never had any problems before. It said that the Powerball tablet has excess foam that is damaging switches that control the door. We are going to try and figure out how to fix it and stop using that detergent.
  • Anonymous May 24, 2008
    pcb=Printed Circuit Board
  • Anonymous Mar 14, 2014
    After washing cycle is complete, soap bubbles still remain in the bottom of dishwasher. I have to do another rinse cycle to completely rid dishwasher of all the soap bubbles.
  • Steven Allen
    Steven Allen Sep 22, 2017
    I have personally had this happen as a result of placing a dish in front of the dispenser door. If yours does this constantly, either the solenoid that operates the latch is defective, a connector is loose, or the control board that activates the solenoid has failed. Check to be sure the door moves freely by hand. If it binds at any time other than closed, that could be your culprit. Let us know...
    Problem Solver:
  • 11 Answers
Take out the trays and Clean the small holes with a pipe Cleaner. Probley have powder clumped in there
Posted on Sep 22, 2017
    Sergeant:
  • 351 Answers
Its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
Soap running down side of door
Are you using a ultra low suds laundry detergent? If not do so.
Jun 27, 2017 | Dishwashers
The soap door will not open during wash cycle, I tried both short wash & reg wash.
The only experience that I have with this type problem was from having dishes blocking the soap door. You can tell if this is the problem when you open the door. The soap door will then open and the soap will run down the door.
Apr 25, 2012 | Samsung DMT800RHS Dishwasher
Soap box not opening and soap not being used during wash cycle even thought the soap button selected.
The soap door is opened by heating a bimetal bar that bends when electricity is applied. This prevents the door from opening when the cycle is momentarily selected preventing the soap from dumping. The unit is behind the soap cup in the door.
May 27, 2011 | Whirlpool Dishwashers
The soap door does not open during the wash cycle
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
The soap compartment will not open during the wash cycle.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Soap dispenser door does not open during wash cycle. it can be opened with the manual release.
close the soap door and put into diagnostics. most models you can do so by pushing heated dry-normal-heated dry-normal. let it do its test and if the soap door opens during the test cycle, most likely the soap door assembly needs to be changed.
Nov 17, 2009 | Whirlpool Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Dishwashers Logo
4,298 people viewed this question
Top Dishwashers Experts
