Question about Nokia 3230 Cellular Phone
My nokia 3230 keypad
My phone is in good condition when suddenly the menu key just hanged-up and i cannot use it anymore,but i can still use it for texting and making calls..im sure that all the keypads are working properly,the only prob. is the menu keypad..do i need to format it or what?
please help...
I try to format it and it goes back to normal..
thanks fixya..
Posted on Mar 03, 2008
Nokia 3230 some keypad not work
If you're having a problem in the keypad on your phone then ill be suggesting you to please remove the battery in your phone then kindly wait for about 15 seconds.After that please turn on your phone.If you're still having the same problem with some of the key then kindly contact the manufacturer of your phone.
Thanks!
Apr 20, 2011 | Nokia 3230 Cellular Phone
To on my Nokia 3230 mobile set its display hand and display nokia symble and set will be hang up. please help.
try to format using this code first turn off phone>remove sim and mmc>then press both of thish button >* >3 > calling button >on off switch when phone format it ask country select menu u can select ur country and go on......if ur fault solve don't 4get me thanx
Feb 17, 2011 | Nokia 3230 Cellular Phone
3230 me 1,6,8 keypad nahi work nahi kar rahi hai
  • are yar keyad work nahi kar raha hai to sabse pehle uska front bord jo keypad belt k sath laga huwa hai use check karo
  • or uske bad keypad belt change karo lakin wo hard hai so ek hi solution hai koi dusra front bord change kar k dekh lo
  • is se 100% ho jayega ok
  • nahi to key pad ic change karo
  • ok
  • my name is
  • IDRISH 911
  • IDRISHANSARI28@YAHOO.IN
  • KOI BHI PROUBLEM HO TO AAP MUZE PUCH SAKE HO OK
  • FRIEND
  • BYEEEEEEEEEEEE
Oct 25, 2010 | Nokia 3230 Cellular Phone
My nokia 3230 having hanging problem..wat is da problem
Might a chance of virus infaction. Please scan your mobile by updated mobile anti-virus. If not done then i suggest you please format the phone & install the updated version. Thanks.
Mar 02, 2010 | Nokia 3230 Cellular Phone
Joystick and keypad run loose or out of control
There are two board on 3230 first main board(engine) 2nd front board that contains camera,display(LCD) ,joy stick,keypad menu, etc.So to fix the problem are change your front board.Good luck.
Oct 12, 2009 | Nokia 3230 Cellular Phone
Hanging problem
hi
there are a couple of reasons why your phone might be hanging
1. some software that might a problem
2. memory card problem
3. if u have recently changed the cover and/ or keypad which might not be fitting in properly
well of all things try a soft reset by dialing (*#7780#)
>>beware to loose all data on the phone with the following step so backup before u do so
the hard reset (phone format)
hold the three buttons Green&3&* and power button
hold the keys till a display FORMATTING appears on the screen
u will loose all data on the phone
cheers hope i helped
Jun 23, 2009 | Nokia 3230
My 3230 phone is switch off while calling
First check the battery connector make sure it's press well.if still switch off, You have to change your PA IC(used phone to transmitt).Battery dropp when calling is the sign off PA IC not in good condition anymore.To change PA I suggest to take to service center,But if you are the expert one,just do it.I hope it helped.
May 07, 2009 | Nokia Consumer Headset
Keypad doesn't work
good morning ! the problem of your 6233 nokia is keypad main brain or keypad crystal ic ,,,,try to clean the keypad mainbrain or replace the keypad ic ! thanks ! good luck ! ......
Sep 07, 2008 | Nokia 6233 Cellular Phone
Nokia 3230 boot failure or cannot star-up
Do a Full phone formatting following steps below:
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
  1. Green dial key,
  2. * Star key,
  3. no. 3 key on keypad
and then press the power on/off to switch on the phone.
Do not let go the 3 'press and hold' keys until you see a the word 'formatting' is displayed on the screen
Aug 05, 2008 | Nokia 3230
3230 problem
NOKIA 3230 KEYPAD NOT WORKING
Aug 10, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
101 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
