The model RS2530 was a Best Buy model and possibly has only one evaporator in the freezer compartment. Sounds like you are having a couple problems. The dual water control valve is leaking for the ice maker and causing the water to freeze in the fill tube for the ice maker. A mess I know! As for the too cold problem I believe that is related to a thermistor located insid the fresh food compartment that is defective or a auto damper sticking open and allowing cold air to flow without control into the fresh food section. i'm sending you a service manual that covers the next model up than the model you say you have. I would like you to tell me as you look through the manual any diffences you notice and there will be because Best Buy made the RS2530 a basic model. It is possible the problem will be the auto damper if your is this mosel. Click here=> RS2531 I will need you to work with me on this one to resolve these problems. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Here=> Sea Breeze Tip's
In manual on page 9 of the PDF the air damer and thermistor may just be the problem with over cooling. The water control valve also will need replaced part number Click Here=> DA74-40149D to stop the ice from freezing in the ice maker fill tube.
Sea Breeze
