Question about ASUS Z71 (90-N9Q1G1000) (90N9Q1G1000) CD-RW/DVD-ROM (Combo) Burner
Speedometer a 2004 silverado speedometer reads 100mph while actually at 50 mph
  • 2 more comments
  • nolane Oct 24, 2008
    I also have this problem with my 2004 Silverado speedometer. Seems there definitely needs to be a recall by GM on this !! It is all over the internet.
    Mine will occasionally start out at 50 MPH while I am just sitting still. Then when I turn off truck...and restart, it drops about 10 miles each time till it drops back to 0 MPH.
    Is the speedometer a cable or is it a vacuum type?
  • Anonymous Nov 21, 2008
    2003 silverado speedometer reads 100-120 when your going 50..... seems like a safty hazzard to me .
  • Anonymous Dec 12, 2008
    I have the same problem om my 2004 truck. The speedometer is part of the whole electronic cluster .Chevy wants a lot of $$$ for the cluster . Used 1's are high to.
  • Anonymous Dec 26, 2008
    my 2005 silverrado speedometer want work right it said 20 mph
    when you going 60 mph
  • 4 Answers
EASY to fix it yourself, or by anyone you know who is handy with tools for less than $40.
This is a known issue and a class action lawsuit for the GM SUV's is already under way, but not for passenger cars (yet). The dealers will commit criminal fraud by pretending to not know whats wrong and will charge you to replace everything else first. Then rather than replace the faulty components IN the gauge cluster they will replace the entire gauge cluster for hundreds, then charge for reprogramming the old odometer readings into the new cluster. All unnecessary. If they wont give you a firm price with a guarantee to fix the problem complete the first time, just walk away.
Go to ebay and search for user MANDIGITAL or search for "speedometer" "stepper".
You can get a set of 6 replacement stepper motors for about $40, enough to rebuild every gauge, or you can even buy just ONE for less money. This guy also has a service to replace the motors for you but you still have to take out the gauge cluster to ship it to him.
These little plastic motors (the size of a ritz cracker) simply position the gauge needles by computer command. A tiny bit of soldering is required to replace each one, and you just follow the included directions. I did mine in about an hour start to finish. Works perfectly now.
Heres a dashboard disassembly with pictures.
http://impalahq.naioa.com/HowTo/Dash.html
Here the process photographed from start to finish:
http://www.sound-expressions.com/rides/avaspdrpr.pdf
Finally, for those folks peeved about GM, I will say this in their defense. These components are not made by GM, and do not fail until after 4-5 years of use. GM could not predict this. They should however, start replacing these clusters as its a safety issue. Also, it is not GM that rips you off at the dealer, its the dealer. These are privately owned franchises.
NTSB will probably get the recall to happen, but it takes time. Keep logging complaints at NTSB :)
GOOD LUCK !
Posted on Jan 24, 2009
2002 Silverado speedometer reads 100mph all the time
Stepper motor inside the instrument cluster could be bad or info from the PCM to instrument cluster is wrong .
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on the information from the vehicle speed sensor. The IPC receives a class 2 message from the powertrain control module (PCM) indicating the vehicle speed. The IPC calculates the vehicle speed based on the class 2 message indicating the wheel reference speed from the electronic brake control module (EBCM) if:
• The PCM detects a malfunction in the vehicle speed sensor circuit.
• The IPC detects a loss of class 2 communications with the PCM.
The speedometer defaults to 0 km/h (0 mph) if the IPC detects a loss of class 2 communications with both the PCM and the EBCM
Feb 09, 2017 | Cars & Trucks
Hi have a 1998 chevy convertion van 163 miles.runs very good...lately the speedometer gets crazy after 40 mph and when get to 100mph try to shot off.... Any sugestions?
At 100 mph the PCM may be shutting it down as a rev or speed safety limiter. Is it jumping to 100 or are you actually running 100 when it tries to shut down ?
Apr 16, 2016 | Cars & Trucks
Speedometer reads 100mph when you are only doing 60mph
Your speedometer is registering kph instead of mph. It can be changed the by the metric/sae button on your dashboard.
Feb 16, 2013 | 2006 Buick LaCrosse
It is a 4x4 and I cant find the speed sensor that operates the speedometer. The speedometer sticks at 100mph at a dead stop. It also jumps around between 75 and 80 at random when I am only doing 45 mph.
On our Lincoln, the problem was the Alternator shorting and energizing the ground circuit with Positive juice. Our speedometer and odometer were both affected.
We had miles advancing and 45-50 MPH at a stop. Then inaccurate readings while the car was moving.
Car-stuff.com seems to have the best price for the actual speed sensor which is located in the differential @$11.94.
Please rate my solution and I hope I was helpful.
Nov 07, 2012 | 2001 Lincoln Navigator
1998 plymouth voyager speedometer reads 15 over
I would suspect you have a faulty electronic speedo head, have the cluster removed and have it sent out for repair of the problem. There is no at home repair procedure for this problem, it takes special equip to repair the speedo.
Oct 08, 2012 | Cars & Trucks
Speedometer needle keeps sticking at about 50 mph when truck is shut off and staying over 120 mph no matter what speed i am actually running. so far the only solution to reset it seems to be turning the...
your cluster is bad mine did that then stopped all together, if you have less than 75,000 miles check with dealer about the gmc recall, if your over that check out ebay for repair and replacement just make sure whoever you get it from is gonna program it to your vin and miles
Feb 24, 2010 | 2004 Chevrolet Silverado
Speedometer surging. actual speed 40 mph,
Its a loose connection on the speedo cable. its a b*tch to get to. I had the same problem on my truck, it would fluctuate in 5th gear on the highway. i spent the money and had a professional do it.
Aug 09, 2009 | 1990 Cadillac Allante
Speedometer
The stepping motors in the gauges go bad. do a search on ebay for CHEVY SILVERADO INSTRUMENT CLUSTER for cheaper repair options. The dealer charges around $300.00. It will continue to worsen.
Oct 26, 2008 | 2004 Chevrolet Silverado 1500 Crew Cab
Acually it's a 2004 Silverado Speedometer problem
Sounds like your speed sensor (odometer sensor) is failing or failed. This sensor is found on the tranny. Best to consult your local dealership.
anaanymous
Oct 09, 2008 | 2005 Chevrolet Impala
Computers & Internet Logo
439 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
