Question about Philips PET710 Portable DVD Player
Nothing ever plays
Making noise like its trying to open video but never shows anything on screen, just keep making the noise like its going to at any moment.
    President:
  • 814 Answers
You can try to reset the dvd Player to the factory specification by using the default option in the preference menu. Use the remote control and push the set-up button. Use the up and down arrows to highlight the preference option. Press ok and enter the sub-menu. Use the up and down arrows to highlight the default option and press ok.This will reset the DVD player to the factory specifications. If this does not work for you . Try cleaning the DVD lense with a cotton swab and a small amount of isopropyl alcohol. Put a small amount of alcohol on the tip of swab and rub it back and forth gently across the lense, until it appears bright and shines. Also check the laser transport and see if it need cleaning of the dust and debris that can accumulate in the in the
dvd compartment. Use cotton swabs with small amounts of alcohol to clean the transport rails and gears.Check to make sure the action of the transport is not impeded by any dust or debris. Also check the gears and make sure they are clean and look in good working order. After doing all this take a can of compressed air and blow all the dust and debis from the dvd compartment. Try playing a cd or dvd and see if the palyer is working properly. If not check the spindle and make sure it is snug and working correctly, holding the dvd correctly for the laser to read it. If it feels loose try using a drop of super glue to make it snug again.Try playing a cd or dvd and see if the player works correctly. If not then you probably are having a problem with the laser lense itself or the motor drive. They may have lost the ability to run under specifications due to useage or ageing. For these problems you should call Phillips Customer support at 1-888-744-5477. Give them the modle number of your dvd player and the problem you are having with it not being able to read discs. They will be able to tell you how to have it serviced and repaired. I hope this information helps you with your problem.
Posted on May 31, 2009
2 Suggested Answers
  • 476 Answers
SOURCE: never show video
There are 3 possible causes for this problem:
1) Dirty lens - clean the lens with a lens cleaner or a non-abrasive foam cleaner on a cotton swap & leave to dry. If this doesn't work try the next option.
2) Hardened grease on the laser track - If the track grease hardens, it will impede the movement of the laser. - Turn the device off, and GENTLY push the laser to the outermost position from the centre. This will redistribute the track grease. Try a disc again.
3) If 1) & 2) haven't helped, then the problem is most likely a faulty laser or mechanism, which would have to be replaced.
Posted on Mar 02, 2008
I can't hear sound/music from my IPod. I've tried plugging it in the iPod cable an USB cable. The screen shows that it's playing but I can't hear anything
Make sure your volume is turned up on your ipod and in the car make sure nothing else is playing. Also check your instruction book and if all fails take your car back to where you bought it from and explain what has happened also make sure it's properly pluged in!
Jul 09, 2013 | Car Audio & Video
Jvc gr-d820ek screen not working
Do the videos work when viewed on a computer or TV (if using HDMI or other connections for TV)? If the camcorder still records video, but the screen itself isn't showing anything, then the screen needs replacing. If it does not record videos, then it's an internal repair issue.
May 28, 2013 | JVC GR Video Cameras
I can't get any web player to stay full screen. Youtube, Megavideo, JWplayer, tvdex, hulu, the list goes on. Please help. It isn't fixed by changing the accelerate video settings thing.
If megavideo is full "web browser" page size click the image/player after you hit the green play button and the video is playing, then it opens a new window with the small player in it, then hit the only dark grey button that falls down screen that says like "cinema on" to turn it off and make the player show, play the video, and now you can full screen it and keep it full screened! If plugin questions keep popping up it's because spam ads or the video itself needs you to keep pushing yes.
Jan 31, 2011 | HP Computers & Internet
My xbox 360 is freezing while playing any game, it lets me play for maybe a half our sometimes, but when it does freeze the sounds in the background continue to play but the screen is completely frozen. I...
Yes this is freeznig up that is caused by overheating you need to stop the heat build up getting to the chips to make it work, use a good repair guide or send it in for a fix.
Aug 15, 2010 | Microsoft Xbox 360 Console
Same kinda thing
that would be your graphic card replace it and your xbox will work like new
Jul 13, 2009 | Microsoft Xbox 360 Console
Frozen screen/ beeping noises
If you go to (http://fixyouripod.weebly.com) you can view free iPod repair videos about this kind of issue
Jan 01, 2009 | Apple iPod nano 3rd Generation
Never show video
Mar 01, 2008 | Philips PET710 Portable DVD Player
Intermittant problems closing the cassette holder and playing the video (using the camera)
I am currently going through the same thing this camcorder has been nothing but problems for me. I don't even use it very often
May 13, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Cannot watch anything
Just head cleaning cassette and play ones
Feb 10, 2007 | Sony Handycam DCR-TRV33 Mini DV Digital...
Philips PET710 Portable DVD Player Logo
168 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
