Question about GE 24 in. GSD4910X Built-in Dishwasher
Ge Dishwasher (GSD4910) display doesn't work
Our Ge Dishwasher, modelĀ GSD4910 just stopped working but the display stays lit. There are no error codes either. The touch pads on the display won't reset or anything. Then it would beep maybe once a minute. I turned the circuit breaker off all night and when I turned it back on this morning "PF" was displayed but the display still won't react when I press it. Any ideas? At least the beeping stopped.
Powerman
  • 68 Answers
SOURCE: F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Posted on Nov 04, 2007
  • 5 Answers
SOURCE: Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
Posted on Jun 03, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
  • 77 Answers
SOURCE: dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Posted on Apr 21, 2009
SOURCE: handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Posted on Apr 30, 2009
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
Frigidaire Gallery Series Dishwasher - unit stops near the final rinse cycle without draining - "ER" on front display, all led indicators on front display also lit (e.g. low rinse agent, etc.),...
the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes.
it can also be the new electronic module.
If the electronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Apr 03, 2008 | Dishwashers
Frigidaire dishwasher model pldb998ac1
If you use salt, maybe that needs refilling. Can't think what else would be low
Nov 08, 2017 | Dishwashers
Drain stays open after start so water doesn't stay in dishwasher for wash cycle. Model GLDT696TSS
Looks like a pressure switch problem. Refer part 26 in this diagram. The drain pump operates instead of the wash pump.
Sep 22, 2011 | GE GLDT696TSS Builtin Dishwasher
I have a GE quiet/power2 MOD D5560LOOSS It doesn't release the soap from the dish. It wasn't cleaning dishes well and then it completly stopped. I have tried different settings. It sounds as if...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 13, 2011 | GE Dishwashers
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
GE Model GHDA480N00WW non-responsive
Im having the same problem with mine.. Did you find a solution
Jun 23, 2009 | General Electric GHDA480N Built-in...
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
CODE F4 and washer not working
Not too sure on that code, could be timer error. One thing to try would be to turn off the AC power to the unit and let it stay off for 15-30 minutes and then turn it back on. Sometimes if the unit takes a voltage spike it hashes the memory and resetting the power will clear it up, but to do this the voltage needs to turned off at the fuse/breaker box and not just the switch on the front. If you have the manual it may give ideas. I could not find the model no. you listed. Check to see if it is correct if resetting the unit doesn't help.
Feb 01, 2008 | Whirlpool 24 in. ADG6962iX Built-in...
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
Dishwashers Logo
46 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
