Question about Sony KP-48V80 48" Rear Projection Television
Powers on but just clicks
48'' Sony Rear Projection
When I press the power button the t.v. just makes a clicking noise.
And the led up fron just click on and off.
I just replaced both Convergence IC's and it whas fine, then a few days later it is doing this...
Any ideas???
    Problem Solver:
  • 11 Answers
This is an old post, but sounds like the ray tubes are out of whack and need to be adjusted. Mark each RGB dial and turn each one little by little until you get it to come one and fine tune it after it's going. This is described in more detail here:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Aug 14, 2008
Wont turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 22, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Crackling noise on tv
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.When it's not able to provide power to the lamp it will flicker,cause the tv to shut on and off .You will need to replace it.Price varies from $40.00 up to $100.00 This procedure is fast and easy.Have a bless one!
Apr 02, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony clicks green led flashes but no sound no picture a dark screen only...there' s breif sound like a fan blade churning just a few seconds..
Hi,if your tv is 2-4 yrs and have not replaced the lamp it might be time to replace it.Do you hear clicking noises and have replaced lamp before it could be the board that powers the lamp its called the ballast.You can find original philips lamp in here : http://www.discount-merchant.com/SearchResults.asp?Search=XL2100+?Click=48173 Have a blessed day!
Nov 12, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My mitsubishi tv turns on for 3 seconds then turns off
Hi,If you hear continueous clicking most likely is t an issue with the ballast which is the board that powers the lamp.But if you dont hear it often and tv is between 1-2 yrs most likely it's time to replace the lamp.
Oct 05, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Tv not turn on
bulb is burnt out remove and replace.
Jul 05, 2009 | Sony KP-48S70 48" Rear Projection...
Tv will not turn on
its a clicking of switching relay. cannot power on due to power supply failure.
May 30, 2009 | Sony KP-48S70 48" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Clicking and powering off
That's just the relay switch in the power supply trying to come on. Because it clicks right off it sounds like you may have a short in the circuit (power supply or high voltage). Get it looked at by a professional.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
MY TV DOES NOT COME ON AT ALL
I have seen this symptom when the vertical output IC has cracked or burned out, and the set is shutting down to protect the CRT's. When you press the power button the computer clicks the main relay and the set powers up, but a fault is immediately detected and the computer shuts the relay off, giving that double click sound. The circuit should be repaired by someone with experience.
Jun 27, 2007 | Toshiba 50H72 50" Rear Projection...
Sony KP-48V80 48" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
