Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint aquarius 1300
The drive belt has come off the machine how do i put it back on??
  • 121 Answers
It takes a fitting stap to fit but can be put back on by hand little tricky but can be done no probs
Posted on Mar 03, 2008
How do i put a belt on hotpoint aquarius wf540
Afternoon,
I had a similar issue myself and I found the below link quite useful
http://www.buyspares.co.uk/how-to-change-a-washing-machine-drive-belt/advice-centre.pl?article=30
I also brought the belt off the site too and arrived next day - all in all I was a very happy customer, hopefully you will be also.
Feb 23, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint drive belt
un plug appliance, remove lid and back plate, place belt on motor and carefully on drum pully, turn pully to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i fix on a drive belt to a washing machine?
There is a removeable cover at bottom rear of washer..
Undo this, and you will see the motor and belt.
It will be very tight to put on, but this is normal as it is a stretch belt, that is why there is no adjustment on motor.
Hope this helps you .
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius tumbler not turning belt was off so put it back on and still tumbler not turnig altho bottom motor is working
the belt didn't get put on the idler pulley and does not have enough tension to turn drum, recheck belt routing
Nov 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drive belt came off Hotpoint Aquarius WT540
At each side of the lid there is a small plastic cover. Remove these then take out the screws. Lift the lid at the front and push it back then lift off.
Thankyou for using Fixya.
Jan 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius belt slippped
Hi.
It sounds like your washer may have a major problem.
If it was so noisy, it sounds to me as though the main drum bearings have gone, or the motor bearings, that being the case, I woukld recommend that you do not use the washer until it is checked out.
Hope this helps!!!
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Fitting "Bushes
you will have to remove the back then the motor then the motor brushes
Aug 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
109 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
