Refilling inkjet cartridge!!
Hi!! How can i refill my hp deskjet 980c printer black cartridge. A new cartridge is expensive to change every now and then. Please help.
  • Ansarac Mar 01, 2008
    ok!! But what kits are available and what make to buy. thank you very much for the procedure nobody cud have made it simpler. Now i think i only have to get my hands on one of those kits.
    thanks,
    Ansarac
    President:
  • 2,072 Answers
Have you purchased a refill kit yet ? If so there are great instructions with them. but generally there is a rubber cap on the top of the cartridge you remove. You draw the ink into a syringe and slowly inject it into the cartridge. Slowly is the key. Replace the plug and tape over it with the tapes they provide. Its important you get the sealing done right or air will enter the top and the ink will flow out of the cartridge into your printer.
It's really not hard at all, just follow the procedures carefully and in 10 minutes you will have the cartridge functioning again.
Just follow the directions, you will be fine.
Posted on Mar 01, 2008
  • Rick Kasper Mar 01, 2008
    Walmart, Circuit city, staples all have them. If you dont have on eof those stores available, go on google and look up refill kits and you can order them online.
Inkjet refill kit does not have instructions for HP 98 -- where do I inject the ink, on the top or botton of empty cartridge?
Posted on Jul 26, 2008
I have a HP 1460 printer & I have now no black ink in my printer.can this printer support any duplicate cartaige(local cartaige)?
No, that printer only uses the 21 Black and 22 color cartridges. The best thing to do when you run out of ink is to buy a refill kit and then refill each cartridge at home. This saves lots of money in the long run. Click on the link below to view a refill kit for your HP D1460:
http://cgi.ebay.com/Refill-ink-HP-21-Deskjet-1420-1430-1460-BK-4oz-s-/320621581336?pt=BI_Toner&hash=item4aa6891418
Feb 13, 2011 | HP DeskJet D1460 InkJet Printer
My printer model is HP Deskjet F4288 All in one printer. Recently i ve brought new Color catridge and re filled Black and white catridge today but still it is showing not able to take print out.
OK, HP recommends that new HP cartridges be used rather than refilling. I've had better results with new cartridges that are name brand than trying to refill to save money.
Feb 04, 2011 | HP DeskJet F4280 All In One Printer InkJet
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I have got an hp deskjet 2480, i have just refilled the original cartridges but printer is printing poorly. Are original cartridges suitable to refill?
The simple answer is no,the main differences after you have given the cartridges a small shake is when you refill the cartridges,which are not supposed to be refilled your ink is not the same viscosity(density and (thickness!) as manufacturers products.This is why your quality is bad,I know it is an expensive buisness and thats why the printers are cheap in the first place --because profitt is made on cartridges.
Aug 18, 2010 | HP DeskJet 920c InkJet Printer
Hello,after refilling ink cartridges HP21 and
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
May 10, 2010 | Office Equipment & Supplies
Printing problems
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
Dec 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
Oct 08, 2009 | HP DeskJet 882c InkJet Printer
HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Jun 16, 2009 | HP DeskJet D1460 InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
95 people viewed this question
k24674
jasbo
jasbo
