Question about Dryers
Hotpoint aquarius condenser tumble dryer
Product operates normal for approx 5 minutes then cuts out,allow to cool and it restarts with same result as previously describe.I have cleared all intake vents of debris to avoid overheating. probably a thermal cut-out ,but where?
The same problem happened to me.it was the relay switch.
Remove the top of the machine by unscrewing the two screws from the top back , pull the top towards the back to remove,at the top of the front of the machine in the middle you will notice a brown smoked see through plastic switch with wire conections at each side held to front panel by two screws,just loosen the left screw and remove the screw on the right, remove the switch by pushing to the right, you may need to bend up the panel a little to get it out,transfer the conections to the new switch remembering where each one goes,slide the switch into the loosened screw and replace other one.
Thats it ,your machine is ready to go. a relay switch will cost around £30
Posted on Dec 11, 2008
  • 156 Answers
Possible the thermo cut out on motor replace motor
Posted on Mar 03, 2008
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint aquarius tdc32s not heating up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Sep 03, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryer cutting main power off after acouple of seconds
you need to ck the back off the dryer and open the small cover wher the elet cord is ateched . it may bo loose or need to replace the block.
Apr 14, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Dryers Logo
118 people viewed this question
Top Dryers Experts
Marvin
Marvin
