Question about DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator
Heater Has Bad Odor
My heater smells like it is burning plastic. It doesn't seem to be overheating but I can't tell. After it has been on a while it makes the entire room smell bad. Any idea why this would be?
  • ebrister Nov 08, 2008
    Smells like diesel when on. I bought mine at home depot - I should have noticed that more than half of these units were repacked (meaning a lot of people returned them). I used it for 1 day and it was horrible. when i returned it the next day, the guy processing the return was talking to his buddy saying "another one with oil odor problem"
You are meant to run them for two hours on full power at first in a well ventilated area to get rid of the packing salt - This really helps.
However, I have returned three of these as they are defective.
Posted on Mar 10, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Gas appliances emitting odor
Sounds extreme but give your local Fire Station a call. They will be happy to break the monotony of the day at the fire house and come to your house with a sniffer machine. It will tell what the odor is? Then get a furnace engineer to check over and service your appliances.
It sounds to me like you might have a blocked flue, and that will cause carbon monoxide poisoning.
Let me know how you get on.
Feb 03, 2016 | Heating & Cooling
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
Aug 16, 2014 | 2008 Chrysler Sebring
Radio, blower to heater, windshield stops and then smells like something is burning
There are several things that may cause those issues - and they are all potentially dangerous ( and labor intensive )!!There could be a bad ground point, burnt or pinched wire, bad relay, poor /corroded connection to the computer, etc. I'm sorry, but this is something that requires a hands on by a knowledgeable technician!
Sorry for the bad news, and thanks for using Fixya!!
Mar 28, 2014 | 2005 Pontiac Grand Prix
Bad Odor on the Lakewood Oil Filled Electric Radiator Heater
Pull the 4 small screws from top & bottom of plastic cover (2 under plastic tab on top, pry off) and then check ALL connectors and all wires. Chances are one of the leads has been overheating and smoldering (mine burnt wire off on lower Thermal switch.) You may need a KDS 301themal switch matching the one in your heater. Google for sellers.
Jan 16, 2012 | Lakewood Oil-Filled Electric Radiator...
Our rinnai avenger 25 gas heater has a gas smell that is overwhelming in our house. Is this a common problem? How and where do we fix it ?
No. it's not common. Or at least not, if it's regularly cleaned and serviced. However, I would caution you that many strong household odors are picked up by the heater and made to smell 50 times worse. If it doesn't smell like rotten eggs, it's not gas you're smelling. It's something else .... have you painted recently or stained the wood work? Have you had the carpeting cleaned or are you burning scented candles while the heater is in operation? All of those things and instances can cause the heater to smell. That's because the heater uses interior air for combustion, so whatever is floating in your household air (dust, lint, pet hair and odors) eventually goes into the heater. If you answered yes to any of the above, stop using the heater (turn the pilot light OFF) for a week or two, until the odor that i's picking up has completely disipated. Paint on the surface may feel dry, but underneath it isn't.
Now, please don't get me wrong. I have been in the hearth and home business for 15 years, now and Vent-free or Flue-less or Ductless heaters are our primary business in the Fall & Winter. They are 99.9% efficient and are totally safe, when properly used and maintained. Over 1 million Vent-free Gas Appliances have been sold and installed worldwide in the past 10 years. There has NEVER been a death related to any of these products. In fact, they have more safety features built-in to them, to shut them down if something goes wrong, than a gas water heater or a Vented heater does.
Now, lets get back to your issue. If in fact, if it is gas you smell and the odor is not caused by the things I listed above, there are a couple of things to look at. Do you only smell the odor when the heater is in operation? Do you smell it with just the pilot light burning? Or with both? How airtight is your home? If it's a recent vintage home and it's really airtight, you may be getting what's called "After Product Burn Smell". This occurs frequently in airtight, new home construction, because there's no air exchange in the house. Unless, you open a door or a window once in a while, to allow fresh air in. Also, the Btu output of your heater (38,400) may be to high for the area you have it in. Unfortunately, it's not a case of one size (Btu Output) heater, fits all.
Other causes for the gas odor can be related to the burner(s) being dirty (incomplete combustion) and needing cleaning. Old gas in the tank or a low level of gas in the tank. The inline gas shutoff valve, not being fully open.
If after reading and troubleshooting all the things I listed and the problem is not solved, you need to contact the dealer you purchased this heater from and have them make a service call to your home.
To help you further, in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Portable_Convectors_TRE_Models.pdf
I hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 22, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a 30,000 btu ventless mr heater for two months it has run with absolutely no smell,the other day I did some wood staining, now the heater has a strong co2 smell is their any way to clean the heater...
Sure is. Never operate a vent-free gas appliance (not even the pilot light) while painting, staining, cleaning carpets, etc. It picks up the odors and will not burn the odor off, because the odor doesn't get in the heater, it just makes the odor worse. You will need to turn the heater off and not use it, until ALL of the odor from the staining have completely dissipated . It may take a week or more, even though you may not be able to smell the odor from the stain, the warm moist air from the heater will activate it again. If you get a warm day soon, open a window or two and let the fresh air in. That will help dissipate the odor. But, allow a week minimum, before trying to use the heater again.
Oh, by he way, that wasn't co2 you were smelling. co2 is dry ice. It has no odor. Just like co (Carbon Monoxide) it has no odor. You were smelling the fumes from the stain. Just 50 times worse.
Good luck to ya,
Rich
Mar 02, 2011 | AOC Heating & Cooling
70,000 btu reddy heater, starts right up but smells bad.Instaled new filters , fuel and igniter low hours 100 or so. disassembled tip everything looked perfect.nosecone turns orange from bottom up and...
I hope you are burning K1 kerosene as opposed to off road diesel. Diesel stinks no matter what you do to the heater. A couple things that have happened to me are, fuel selection K1 is it, when storing for the end of the season old fuel can cause water from condensation to build in the tank. When water is in the tank you get ignition and it burns just not hot enough to burn the fuel completely, this causes the heavy odor. Old fuel will do the same it is as if the fuel thickens to an oily state and becomes heavier. It just does not burn hot enough to get rid of the odor. You can try increasing pump pressure this changes air fuel mixture and you may get rid of the odor somewhat.
Dec 23, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Bad odor, burning eyes from fumes.
It sounds as though some Plastic part is being heated up to Fuming Point, being melted, and releasing toxic gas, I would advise not using it until you can get it looked at by a professional.
Feb 20, 2010 | Procom ML300HGA Heater
Reddy Heater 60k kerosene suddenly smells
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 09, 2009 | Reddy R60A Utility Heater
Open Questions:
DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator Logo
1,664 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
