Question about Honeywell Programmable Thermostat Heater
Central heating Should a thermostatic radiator valve turned to 0 setting stop water coming through the radiator?
    Problem Solver:
  • 16 Answers
Or put it on frost setting if you can take head off spray with a little wd40 around needle and put head back on with head at max then turn down to frost or 0
Posted on Aug 17, 2009
Niagara delta 30ff combi boiler, 13 years old. problem when the hot water for bath heats, the radiators in the house also starts heating, even after central heating thermostat is switched off.
sounds if your zone valve isn't closing off and the circ pump runs all the time ?? ck to see if zone valve gets power all the time or only when thermostat calls for it , if power is only there when called for then your valve is bad (common)
Jun 02, 2017 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Central heating not working but hot water is ok.
If when you turn power off you wait a while it is probably not the central system coming on. You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in. try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 13, 2014 | Water Heaters
Central heating boiler will not heat heating water
first do not call engineer go up in loft if there is a lot of insulation in loft have some boards to lay down in loft you will have two water tanks one large and a much smaller one look inside the smaller one and if the ball valve is stuck in the upright position and no water in tank move ball up and down water should flow wait for tank to fill then bleed radiators with a small key obtainable at most diy stores for this you will need a small towel with key hold towel under valve loosen the screw at top of radiator air will escape then water will escape do this to all radiators repeat this a second time so only water comes out turn on heating system also there is a chance you will have to turn down heating system
Dec 02, 2012 | Water Heaters
When i put the water heating on my boiler gets the water hot but just heats the radiators,even when the thermostat and controls for the central heating is of and get no hot water at all
you have a zone valve and a tank stat that controls the temp of your hot water. when the water reaches the temp set of the tank stat the zone valve closes and stops water going to the tank. turn up the stat and see if the valve opens. you will hear a wherring noise. if not working you may have to change one or both of these but you can put the valve on manual by moving the lever in the side of it to then manual position till you get it fixed
Nov 27, 2009 | Kitchen Ranges
Heating & Cooling Logo
63 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
