Question about RCA D52W19 52" Rear Projection Television
Off color i have a 52 inch rca hdtv model # D52W19 a couple days ago i lost my darker colors like purple but have lots of brights like green what could be the problem and will it be a easy fix. thank you
  • butch874 Nov 17, 2008
    It seems like I lost all shades of red on my screen. Blues and yellows seem to be fine. Could this be a tube as well?
  • 1,030 Answers
Hummm i wonder if you may have lost one of your projection tubes... like red or blue.. that would be my first instinct and i would have to remove or at least get the screen loose enough to see if all tubes are lighting. tube replacement on these are somewhat difficult and expensive. 250 just for the part and prob another 250 for labor. but if its not the tube it could be screen control adjustment of focus pack.. so here hopeing..
Posted on Mar 01, 2008
My RCA 55 inch DLP HDTV needs the color fixed. It keeps showing purple and green on the screen
color wheel is getting ready to fail which is causing the color wheel to spin slower which cause the index speed to be off so the tints will be messed up.
Aug 22, 2011 | RCA Televison & Video
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
Color ghost
Sounds like your convergence is off. Go into your menu and try setting your convergence. If you can not move any of the colors you need to have your convergecnce amplifers replaced
Apr 08, 2009 | RCA HD52W56 52" Rear Projection HDTV
Green color out
loss of green color indications of failure of green crt. or green crt board. replaceing the tube ussaly cost 250 for part. however tube replacement in these set are very labor intensive. involveing removing and complex setup issues. at our shop it around 500 to replace one tube. rhese set ussaly not cost effective to repair unless under warrenty
Mar 24, 2009 | RCA D52W19 52" Rear Projection Television
Mitsubishi WD-73827 with degrading color
Good Day;
More then likely your 2005 MODEL has a bad "LIGHT ENGINE". Call an Authorized Service Center and have them give you an estimate, then call MIT's and try to get them to give you a "CONCESSION". It's costly. Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
RCA D52W19 (52"HDTV)
The common culprit for this problem is a defective Focus/Screen control block. It is located behind a removable panel in the front under the speaker grill. It is a little black box mounted up along the top of the opening with two rows of three openings for adjustment of the Red, Green and Blue "focus" and "Screen" (brightness) settings. They often get contaminated with dust which is attracted by the high voltage flowing through this block. It is held on by a single screw and has 9 push on/off wires into the back of it. The replacement is fairly straightforeward, just keep track of which wires go where. Leave the set unplugged and powered down for a day or so and the voltages should all have bled away to ground by then.
Aug 01, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
