Question about Apple iPhone Smartphone
Sim card just got an iphone, how do i put my sim card in it? i know the sim tray is at the top but cant figure out what to do with it
  • boknoy Mar 01, 2008
    my sim is blocked... p.u.k..... then i try 2 enter new sim.. but my phone dont wnt 2 accept...
  • suzieq27 Mar 08, 2008
    i dont know how to put the sim card in my iphone i cant see any where for it to go please help
How do i open up the i phone
Posted on Mar 09, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
Open it and put it in.
How to change a sim card in an iphon 3gs
to remove the sim card this requires a very small tool or fine needle or fine piece of rigid wire and insert it into the ejection hole located near the sim card.
Hope this helps
Aug 21, 2012 | Apple iPhone 3GS Black (16 GB)
Tip
How to replace iPhone SIM card
The only thing that you must have is a SIM eject tool or simply a straightened paper clip or any pin-like object hard enough to push-open the SIM tray. BTW, this SIM eject tool came with the box when you bought your iPhone.
Here are the steps:
First, refer to the image below to locate the SIM card tray. To pull it out, you need to insert the SIM eject tool (or the paper clip) on the tiny hole on the top of the iPhone 3G or on the right-side of the iPhone 4. Push until the tray pops out.
NOTE: The tiny hole found on the top of the iPhone 4 is not for the SIM card tray, it is a microprhone. Please do not insert any thing in there.
Once the tray pops out, pull it out completely and replace the SIM with any SIM you want.
When you're putting it back make sure that the SIM carrier logo is facing the front of the iPhone. Don't force it if it get stuck, just pull it out again, and gently put it back.
Here's an image for your reference:
Please read my other tips:
JAILBREAK
http://www.fixya.com/support/r5452955-jailbreak_all_idevices_iphone_4_3gs
UNLOCK
http://www.fixya.com/support/r5537989-unlock_iphone_4_3gs_3g_or_older_ios
on May 06, 2010 | Apple iPhone 3G
How to insert sim card in iphone 3g
Turn off your iPhone 3G and make sure any cords or connector cables are removed from the device. Then, hold your iPhone 3G upright.
  • Locate the Sleep/Wake button and headphone jack on the very top of the iPhone. Between these two components you will see a very small hole.
  • Insert the tip of a paper clip into the hole to release the iPhone's SIM card tray. The small tray will pop up relatively quickly from the top of the iPhone. If there is already a SIM card in the tray, use your fingers to remove it.
  • Insert the SIM card you want to install into the phone facedown in the tray. Make sure the side without the reflecting panel is inserted first.
  • Press the SIM card tray gently back into the slot until you hear it "click" into place. Now turn your iPhone on. All of the information on the card will now be in your iPhone 3G.
  • Mar 16, 2011 | Apple Computers & Internet
    How do you put the sim card in the apple i phone 4
    Apple iPhone 4 uses a Micro SIM which is 15 mm × 12 mm in size while the standard Mini SIM is 25 mm × 15 mm in size. To insert a SIM in iPhone 4, follow the steps below:
    1. Take a simple paper clip and make it straight.
    2. Check the right side of your iPhone 4 to locate the SIM tray on the Right side of the iPhone.
    3. Insert the pin into the small hole and push it slightly until the tray pops-out. Now pull out the Sim card tray with your hands.
    Mar 10, 2011 | Apple iPhone Smartphone
    Cant put sim card in iphone
    theres a sim tray up top which can be removed by inserting a paperclip into the tiny hole
    Mar 05, 2011 | Apple iPhone Smartphone
    I hav 8 gb apple i pnone, but i cant open the sim tray to insert the sim card..pls help me. I am in bangalore , India
    There is a small hole on the top of the phone near the lock button. Insert a thin strong object firmly into this hole. I suggest a paperclip or pin. This should cause the tray to pop out just a little so you can grab it with your fingers
    Jan 27, 2010 | Apple iPhone 3G
    Where to insert sim card in iphone 3gs
    At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
    Put your sim card in the tray and put back in the iPhone
    Dec 25, 2009 | Apple iPhone Smartphone
    How to put sim card to the iphone?
    SIM card slot is in top of iPhone. From iPhone Manual:
    If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
    Install the SIM card:
    1 Insert the end of the SIM eject tool into the hole on the SIM tray.
    Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
    2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
    3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
    Aug 11, 2009 | Apple iPhone Smartphone
    Apple iphone.where abouts do i put my sim card in the iphone?
    Use the supplied tool or a straightened out paper clip to eject the sim tray in the top of the phone. There is a tiny round hole in the top of the phone that you gently push the tool(or paper clip) into to eject the sim tray. Load your sim card and slide it back in and you're done!
    Good luck,
    Dec 25, 2008 | Apple iPhone 3G
    The sim card goes into a slot that is on the top of the phone. Use a paperclip to take the plastic "tray" out of the phone, put the sim card in, then slide it back in.
    Refer to this website for pictures . videos / detailed instructions:
    http://www.iphoneincanada.ca/tips-tricks/how-to-iphone-sim-card-removal/
    Dec 24, 2008 | Apple iPhone Smartphone
    Apple iPhone Smartphone Logo
    60 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
