Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
ZUNE LOCKING SWITCH
My zune is not damaged but it would not unlock even when i moved the external switch back and forth, so i took the back casing off and moved the plastic arm underneath the external lock switch, i tried moving the plastic switch back and forth and it still would not unlock so i removed the plastic arm and tried to see if i could see the problem but i could not, i just updated my device software and the computer still reads the contents of my zune, can you pleaze help me to unlock my device.
  • Microsoft Master
  • 19,396 Answers
The switch contact under the plastic arm is probably broken.
Posted on Mar 01, 2008
  • 796 Answers
Well I guess I'll be using it too on the new Zunes because I think they are going to be a lot more sensitive with the touchpad
  • isaac johny
    isaac johny Mar 01, 2008
    remove the battery and again plug it in n restart it....
    it will work
  • isaac johny
    try resetting the player
    Sometimes a soft reset may be necessary if your player is acting up.
    You may, for example, be advised by technical support to reset your
    player as part of a troubleshooting effort.
    With your Zune
    turned on, press and hold the back (left) button and the "Up" button on
    the control pad at the same time. Your player will reset itself.
I dropped my 1st gen 30gb zune and now my audio is too low i have to put my volume up to max to hear it,i got new head phones and they make it worse is it the audio part of the motherboard or the hard...
If it's working at all it is unlikely to be the hard drive.
It may be a broken track or connection on the circuit board, but again it's surprising it works at all.
Try resetting it. It is so close to working properly it might work.
support.microsoft.com/kb/946064
1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position.
2. Press and hold the Back button Collapse this imageExpand this image zune_button_back.gif while you press the top of the Zune pad. Collapse this imageExpand this image zune_restart.jpg 3. Release the buttons when the Zune device begins to restart.
Feb 12, 2011 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 8 gb hold switch broken tried to over ride switch but dont know where to make connections
Look at the switch when it is in the unlocked positions. There are three contacts, connect the two contacts with a little bridge between which the slider of the switch is located when it is in the unlocked position. That will permanently unlock your Zune. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide, so you can do it yourself too, not that difficult. If you can't do it yourself, have a tech savy friend do it for you.
Oct 18, 2009 | Audio Players & Recorders
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
Lock problem (zune 30)
If it's a zune 30, it's just a glitch in the software timing and so you have to flick it back and forth until it works.
My zune does the same exact thing, it always has. So just bare with them (:
hoprfully microsoft will create a software or firmware update that help itt. (:
Mar 29, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
It died and now wont turn back on
maybe if you restart your zune?
if so u To restart the Zune device, follow these steps:
Collapse this tableExpand this table 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button Collapse this imageExpand this image zune_button_back.gifwhile you press the top of the Zune pad.
Mar 25, 2009 | Sony NWZ-E438F Digital Media Player
I can't unlock my Zune.
it is not that hard, simply move the switch on the to of the zune to the left so that you cannot see any red!!!!!
Aug 22, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30GB zune freezes up when stwitching between songs
MORE INFORMATION loadTOCNode(1, 'moreinformation');To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position.
2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad.
Jul 23, 2008 | Audio Players & Recorders
Broken lock switch zune Pink
My zune lock switch completely broke off in the locked position. I used a paper clip to remove the small plastic tray under where the switch use to be. It came off pretty easily. Then I could see a small black toggle switch can I was able to flick it in the unlock position.
Jun 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Mirosoft zune froze up
To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
89 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
